Farmall Cub
   / Farmall Cub #1
Ortis
Maryland
I have a Cub from the '70s I suppose since it has the squared off hood fron rather than the better looking (I believe) rounded one. It came with a 5' belly mower. i mowed with it for a while, but found that it had too little power to work on moderately thick, high grass or up hills, except in first gear. Now I just keep a blade on the front and use it for pushing hings around and pulling a cart.
Is my experience unique, or is it the norm for Cubs? I know it has only ~14 HP, so why do people like and seek out Cubs?
Regards
Ortis
   / Farmall Cub #2
Check out the Farmall Cub board here. Lots of Cub fans, with plenty of information and ideas. I have a '64 Lo-Boy. I still use it to rough mow paths in the woods. I have a smaller deck and the Cub does a good job.
   / Farmall Cub #3
</font><font color="blue" class="small">( i mowed with it for a while, but found that it had too little power to work on moderately thick, high grass or up hills, except in first gear. )</font>
I had a Cub several years ago and had the same experience. If the grass was 6" tall or I was going up hill: 1st gear had to be used. I always thought the Farmall Super A would be nice. About the same size as a Cub but with much more HP.
   / Farmall Cub #4
</font><font color="blue" class="small">( so why do people like and seek out Cubs? )</font>
Because they are easy to work on and get parts for. Plus they can take abuse.
-Mike Z. /forums/images/graemlins/grin.gif
   / Farmall Cub #5
I have a 66 IH cub.. and it has a 4' IH belly mower. That's all it wants to pull as well. IMHO.. a 5' rotary mower is way too much load.. look at what size tractors are pulling 5' mowers.. 20 hp or so.. etc. If you had a sickle bar mower.. it would pull 5' fine.
Soundguy
   / Farmall Cub #6
Ortis, My wife's tractor is her Grandpa's 1947 Farmall A (18HP). It has a 4ft belly mower that works great for mowing walking and golf cart trails. I also put a the trailer behind it for people transportation. Here it is pictured with the now famous Eddie Walker's girlfriend's son.
   / Farmall Cub #7
they are little enough to go in the garage and they are kinda cute /forums/images/graemlins/smile.gif
Ben
   / Farmall Cub #8
Some things you might try are to get the front of the mower a little lower than the rear so the blades are only cutting once.
Also, if it bogs down grab a lower gear and or only limit the cut to a 1/2 swath.
Cub in action
Tbar
   / Farmall Cub #9
A Cub has only 14 hp or so - but that's at 1600 rpm. That means it has the crankshaft torque of a 'modern' garden tractor of around 32 hp that's rated at 3600 rpm. (say 44-46 lb-ft).
There are some amazing pictures of Cubs in action in the book "Farmall Cub Photo Archive".
Don't believe anyone who insists the Japanese invented the compact tractor, unless they're using a very narrow definition.
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A51039)
2012 Freightliner...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
LAMAR 20 T/A TRASH TRAILER (A50854)
LAMAR 20 T/A TRASH...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
500 gal Fuel Barrel with Pump (A50515)
500 gal Fuel...
2003 PETERBILT 379 (A50854)
2003 PETERBILT 379...
