Farmall Cub
/ Farmall Cub #1
Foozle
Pelzer, SC
Kubota L5740
Hi,
I inherited a Farmall Cub and am trying to find parts to restore it a bit. The face plate is not recognizable so I can't obtain the serial number. My understanding is that some of the parts are dependent on the serial number. Is there another way to identify which model I have? Also, it appears it is using a 12 volt battery currently, but I had thought these were 6 volt tractors.
Any advice is appreciated.
Thanks
/ Farmall Cub #2
Go to the yesterday's tractors website for parts and more advise. Many old 6 volt tractors were converted to 12 volts for easier starting on a worn engine with weak compression. My cub is 12 volt which I like for operating a 12 volt sprayer. The cub is probably the easiest tractor to find parts for after a Ford N, because they were so popular for so many years. These are the only two tractor models I know of for which you can always find oil filters at TSC ($4.00 for the cub filter, $9 for the N when I picked up a couple last night). Do you have any attachments? They really are great cultivating tractors and very good on gas.
/ Farmall Cub #3
9$??? the fram c3 is still 3.99$ at my local TSC.. fits the partial flow oil system on an 8n fine.
soundguy
/ Farmall Cub #4
face plate? What about the tag on the steering box.
In 1966 the cub went to a 12v generator..e tc.
does your unit have the rounded nose.. or the square doff nose? rounded is older. Post a pic of what ya got.
is your 12v system with a generator.. or an alternator. OEM had the genny. it was a-circuit.
soundguy
Foozle said:
Hi,
Thanks
/ Farmall Cub
soundguy
Well, perhaps face plate wasn't the right terminology. It is a metal plate towards the front of the tractor on the right side. I can see remnants of where it looks like it says "model . . ." but nothing more.
I believe it is a rounded nose, but would need to compare to pics to be sure (I think I remember someone telling me it was in the 1945-1955 age range - they weren't sure exactly). I'm traveling for a week but can post a pic when I get back home in a week. I'm pretty much a novice so couldn't tell the difference between a generator and an alternator -- I'm hoping to increase my tractor IQ, in part by reading this forum.
I don't have any working attachements for the Cub (just a belly mower). There are various attachments strewn about the acreage (one has grown into a tree). I'll go around with a camera some day and post here to help with identification.
I also inherited a JD50 which needs a lot of work, like a manifold that is fused into the engine block by rust, heat and time. I ordered all the manuals for that from Deerely Departed and just need time and experience to fix that up.
Thanks for the input.
/ Farmall Cub #6
I've had good luck dealing with ralphscubs.com. They seem to have very reasonable prices. The earliest Cubs (47? 48?) had a screen mesh grille. In the fifties they went to a grille with bars across it, and as was mentioned before, they later went to a square hood, and were mostly yellow. The earlier ones were red. They're great little tractors!
/ Farmall Cub #7
I bought the Fram C3P filter on 5/7/08 for $9.16. Maybe the C3 is cheaper, or maybe I got robbed. The Fram C235 for the Cub was $4.17. Maybe they just charge more for everything up on the Canadian border than they do down in the deep south. Have you been to TSC lately? High shipping costs have moved prices up on just about everything.
/ Farmall Cub #8
Goto farmallcub.com .They are good people and will help you find the year, etc.. Also places to buy parts on their site. The Case IHC dealers can still get most parts for them too, but I try to avoid them if at all possible because of their extreemly high prices.
/ Farmall Cub #9
c3p is overkill.. get a c3. remember .. this is a partial flow filter system.. and the filter is at the end of the line.. the bearings have already seen the junk by the time the filter garbs it..
soundguy
/ Farmall Cub #10
To the otiginal poster.. an alternator is usually a short fat aluminum cased thing.. lookunder your car hood....
a generator is usually long and tubular.. think short 2-litre soda bottle compaired to a soccer-ball-alternator.. etc
soundguy
/ Farmall Cub
Thanks for the info and advice. I'm finally home again so was able to take some pics. Still not sure if it is a generator or alternator, but I'm sure you guys will be able to tell right away from the pics. I think it is running a 12v battery currently - hopefully that is the right voltage (it starts at least).
Thanks,
Dave
/ Farmall Cub #12
Thanks,
Dave
That's a honey of a Cub. Been looking for one in that condition for more than a year. The quest continues.
/ Farmall Cub #13
That appears to be a very old cub because it lacks the hydraulic lift that the later cubs had. As far as usefullness, that is bad, but for collectability, it is good. It even appears to have one original rear tire. If it were mine I would attempt to restore it to a 6 volt system. Without hydraulics, it aint worth much as a "user", but restored to original condition, it would have some good "collector" value.
/ Farmall Cub #14
Congratulations on your new addition! As far as what year you have, Cubs with the 4 bar grille fall between 1958 - 1964. After 1964 they changed to the square flat grille. Prior to 1958 the grille had multiple bars with a strip down the middle.
I have a 1963. As a previous post said, go to farmallcub.com for a wealth of info and tips. Enjoy!!
/ Farmall Cub #15
Nice front wheel weights.
Look at the area above the ignition coil.. follow the fan belt out.. you should find a genny there if it is a long cylinder.
soundguy
/ Farmall Cub
Thanks again for the info. I'll check out farmallcub.com to try to date the tractor. If I ever restore it, I'll probably look into converting back to 6v.
Dave
/ Farmall Cub #17
66 was the first year for 12v on the cubs.. however.. I don't see why someone couldn't have swapped your old 6v gen for a 66+newer 12v gen and then just swapped the coil ( and any lamps ).. that would be all she needed to go to 12v.. etc.
soundguy
2023 John Deere Z960M Zero Turn (A63116)
2023 John Deere...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A63109)
THIS WILL BE A...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
2024 John Deere 6R 130 Tractor Loader (A63109)
2024 John Deere 6R...
UNUSED (4) 295/75R22.5 TIRES & ALUMINUM RIMS (A63745)
UNUSED (4)...
