Farmall Cub Lo-boy Radiator
   / Farmall Cub Lo-boy Radiator #1
Whitey
Slippery Rock, Pennsylvania
Kabota B21 TLB
A friend of mine has come to me about a problem with his Cub Lo-boy, the coolant is dissapearing in his system and he cannot find the leak. He thinks it maybe the radiator......but we cannot figure out how to pressure test it to fix it. Has someone come up with a way to pressure test this type of radiator? Also......if it is bad....any reccommendatons on a place to buy a rebuilt or after market one?
   / Farmall Cub Lo-boy Radiator #2
Try farmallcubforever.com for parts. There are other places that will come up with a seach.
   / Farmall Cub Lo-boy Radiator #3
why can't you pressure test it? no rubber bung adapter for the top?
sounsdguy
sounsdguy
Actually no.......this is my bosses tractor and as I can tell it is completly open at the bottom. He is losing fluid and he cannot pin point the leak. When you take the blasted radiator off.......the bottom is completly open! The bottom bolts on to the engine casting. We could have the radiator repaired but we can't find a leak.:confused2:
   / Farmall Cub Lo-boy Radiator #6
The cub did not have a "pressure" system. The radiator cap has no spring and builds no pressure. Here's a link: Farmall Cub Radiator Cap, original style
Maybe it's the radiator gasket leaking Farmall Tractor Parts and Restoration .
Here's another link to a core Radiator Core - Case / International Farmall Tractor Parts Shop .
Here's a link to how a cub radiator works: http://www.atis.net/CubFAQ/cub_faq_2.html .
Yall haven't mistakenly put a pressure cap on the radiator, have you ??? Or filled it too full.
I know a cub and Super A radiaotor will steam or "perculate" when it has been worked hard.
Chris
   / Farmall Cub Lo-boy Radiator #7
i'm well aware of the cub rad design with cast base. ( i own a cub ) my POINT was to put a rubber stopper into the top of the rad while seated onthe cast base.. add a couple pis air with a blowgun and THEN look for the leak.
soundguy
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2011 KENWORTH T800 (A50854)
2011 KENWORTH T800...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
New Mahindra 8100 CLGC Euro Loader (A50774)
New Mahindra 8100...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
