Farmall A
/ Farmall A #21
I have been looking for new magneto kill cable that was used on the ealier A's. Any suggestions?
/ Farmall A #22
I had a '39 B with that type Mag., with the sliding switch. Seems like it was a Fairbanks-Morse, not the IH H-4. There was no cable on mine, so someone must have taken it off.
I went to Case/IH parts, and found an exploded view of it, and part number "51006D" Official Case IH Online Parts Store and Case IH Catalog for Parts Search and Parts Look Up. Case IH Parts for Case IH Tractors, Case IH Combines, Case IH Tractors, Case IH Manuals, Case IH Parts. Didn't find but one hit, and was through Wengers of Meyerstown. I tried to find it directly through their site, but no luck.
From the looks of it on the parts view, looks like a HD throttle, or choke cable would do the trick. Finding one with the right knob to suit you might take a while though...
/ Farmall A #24
5 quarts. Book calls for straight 30wt. above 32º, but I weaned mine over to 15/40 years back, and have had no problems. Owner's choice I guess...
/ Farmall A #25
same here in my c. multi weight oil.. etc...
/ Farmall A #26
I'm going to order decals for my "A" do I need the ones that have "Cultivison or just the ones with "A" It's a 1940
/ Farmall A #27
Farmall 1.jpgfarmall 2.jpgfarmall 3.jpgHere are those before pictures you requested farmall 55a case
/ Farmall A #28
All A's were cultivision. Gotta' admit... I've never seen a seat on an A like that before..!!
/ Farmall A #29
Thanks!! Have only found one on the Internet with the same seat. Im hoping it is original. Im going to email Case to find out for sure. If it isnt that would explain why I couldn't find the seria #l tag and also if you noticed the tool box that is on it is one that is suppose to be the one that is mounted under the seat. Someone mounted it to the steering Anne and the gas tank support.
/ Farmall A #30
keep the pics coming!
/ Farmall A #31
Make sure you get the Decal set for McCormick Deering Farmall A (pre 1945) without the IH logo and not the Mccormick Farmall A decals.(post 1945). Not sure about the cultivision in the A but my 1941 Farmall A does not have it.
Stiener tractor parts or OEM tractor parts can make up a new serial number plate for you using the serial number from the block for Farmall A as the numbers were matched. Make sure you get the early style plate as in pic. The letter A is in the shaded area in the pic below then the plate is stamped FAA then your serial number .The 1540 is the max RPM. They can also supply a lot of parts used on these tractors.
2009 Infiniti FX35 AWD SUV (A64557)
2009 Infiniti FX35...
46182SFL (A64557)
46182SFL (A64557)
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
2015 Freightliner (A64119)
2015 Freightliner...
72in. Fork Extension (A64553)
72in. Fork...
2016 CATERPILLAR 299D2 SKID STEER (A63276)
2016 CATERPILLAR...
