Farmall A battery question
   / Farmall A battery question #1
txdon
Super Star Member
Central Texas
Kubota M6H-101
When I was taking the 6-volt battery out of my Farmall A to replace it I noticed that the positive terminal was grounded to the fame and the negative went to the starter. Is this right, or does it matter? /forums/images/graemlins/confused.gif
   / Farmall A battery question #2
Yes it does matter. If it was working correctly before, keep it a Positive ground system.
Lloyd
Thank you my support group! /forums/images/graemlins/smile.gif
   / Farmall A battery question #5
Yep, my 130 is the same setup...
   / Farmall A battery question #6
My 200 is the same. i had to do a double-take on it the first time I saw it!
   / Farmall A battery question #7
Most antique tractors that were 6v were positive ground. Mainly due to the edison effect and the spark plugs.
Soundguy
   / Farmall A battery question #8
I was told that positive ground systems had "increased corrosion problems" and that this was one of the reasons for the switch to negative ground... make any sense?
- Patrick
   / Farmall A battery question #9
My understanding is that positive ground had decreased problems...
Soundguy
   / Farmall A battery question #10
I have always wondered why the move from positive ground to negative ground happened. Not wanting to hijack the thread and this is a non issue with CUT's, but since we are in the Vintage forum.....
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
2021 Kubota SVL97-2 (A50123)
2021 Kubota...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51692)
2006 iDrive...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
Adams 5 Ton HC Spreader (A53473)
Adams 5 Ton HC...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
