Farmall A battery question
   / Farmall A battery question #1
txdon
Super Star Member
Central Texas
Kubota M6H-101
When I was taking the 6-volt battery out of my Farmall A to replace it I noticed that the positive terminal was grounded to the fame and the negative went to the starter. Is this right, or does it matter? /forums/images/graemlins/confused.gif
   / Farmall A battery question #2
Yes it does matter. If it was working correctly before, keep it a Positive ground system.
Lloyd
Thank you my support group! /forums/images/graemlins/smile.gif
   / Farmall A battery question #5
Yep, my 130 is the same setup...
   / Farmall A battery question #6
My 200 is the same. i had to do a double-take on it the first time I saw it!
   / Farmall A battery question #7
Most antique tractors that were 6v were positive ground. Mainly due to the edison effect and the spark plugs.
Soundguy
   / Farmall A battery question #8
I was told that positive ground systems had "increased corrosion problems" and that this was one of the reasons for the switch to negative ground... make any sense?
- Patrick
   / Farmall A battery question #9
My understanding is that positive ground had decreased problems...
Soundguy
   / Farmall A battery question #10
I have always wondered why the move from positive ground to negative ground happened. Not wanting to hijack the thread and this is a non issue with CUT's, but since we are in the Vintage forum.....
2003 Evan's Log Trailer, Super Singles (A52384)
2003 Evan's Log...
2004 MOBILE 500 BBL FRAC TANK (A53843)
2004 MOBILE 500...
2004 Ditch Witch RT70M Ride On Trencher (A53117)
2004 Ditch Witch...
2018 Mac 48ft T/A Walking Floor Trailer (A51692)
2018 Mac 48ft T/A...
CASE INTERNATIONAL 695 TRACTOR (A51406)
CASE INTERNATIONAL...
2005 Kaufman Trailers Trailer, VIN # 15XFW53265L001140 (A53421)
2005 Kaufman...
