FARMALL 55A PROBLEMS
/ FARMALL 55A PROBLEMS #1
farmall 55a case
Platinum Member
case ih farmall 55a
Went out today to the tractor and tried to start it would not start right away! Always starts on the first crank, but today I had to crank it over for about thirty seconds? It runs fine but the it just died on me after it was running for over ten minutes. Not a slow spidering die either! Just like I turned the key off? When I went to start it back up had to crank it over for five seconds or so? Done it to me 6 times in four hours? Other than that it runs great and smooth and has all the power it normally has? Any input would be great! Air filter is clean and I put a new fuel filter on it after it died the second time didn't change a thing!? Thanks for reading and please help!
Believe I found the problem. Fuel shut off solenoid on the side of the injection pump.
Well that didn't fix it! Its a pita to try and fix something that dosent mess up all the time! How do you go about checking safety switches??
Any thoughts?
/ FARMALL 55A PROBLEMS #5
Intermittant probelams are always a bear to diagnose. With the safety switches, just go through and check for normally open or closed according to the wiring diagram. Unfortunately, ti's tedious, time consuming, and a pain. Best of luck to ya on this one!
Worked on it all day Saturday. When it dose die I loose power to my fuel shut off solenoid. Everything else still works! Its not blowing a fuse so I don't think its a short in the wires. I traced them all and the look good. Could it possible be a relay? When it dose die if I turn the key off and weight about ten seconds if fires right back up?
/ FARMALL 55A PROBLEMS #7
Could be anything from a relay to a short in wires to a bad safety switch. Unfortunately, it's narrowing it down as to which circuit is causing power to leave the solenoid and then which part, etc.....
Do relays reset there self or? What exactly is a relays job?
/ FARMALL 55A PROBLEMS #9
A relay is just a tiny solenoid of sorts. It is a magnetic switch.
You apply power on the low amperage side that engages a magnet to throw a switch that is a higher electrical current. For instance, that draw that most headlights have would melt most dashboard switches, so a relay is used so a low current switch can trigger something with a higher amperage draw.
There's tons of things about this on you tube also.
/ FARMALL 55A PROBLEMS #10
From ny experience, if a relay is bad, it's bad. It doesn't go bad intermittently. Not to say it can't happen.......lol
Thank you everything you have explained to me has been very helpful! Its just starting to get on my last nerve. I spent over 14 hrs on it sat.
/ FARMALL 55A PROBLEMS #12
Happy to help with whatever I can. I've got a big project on my own tractor going. Dealer says I'll probably need to split the tractor and the total job is usually around 13-16 hours for the dealer techs.....
I worked as an automotive mechanic for a number of years......but this is still going to be a long one
I wish you the best of luck! What type of tractor are you splitting? And what for?
/ FARMALL 55A PROBLEMS #14
DX33. If you look for the thread "shrapnel in gear case" you'll find what I've got going on
Still no luck I have checked everything and chased every wire! Done great for almost 20 hours then it died on me twice in less than a min. Used it for three hours after that and not a problem? After it dies its takes a min or so to get power back to the fuel shut off solenoid. Could a relay cause this? Frustrated and confused! :(
/ FARMALL 55A PROBLEMS #16
What are you doing when it dies?
Just driving it! It acts like I just reached down and turned the key off! No puttering out or any warning at all! It has even died on me wile it sitting there idling!
/ FARMALL 55A PROBLEMS #18
Unfortunately, intermittant problems really are tough to chase. I would start by seeing if power is vetting interrupted to the fuel cut off. Maybe wire in a light?
/ FARMALL 55A PROBLEMS #19
Does it quit only when you are driving or will it shut down when in neutral not moving, why I ask is I have found that the operator presence switch can be a problem sometimes on rough ground.
It will shut off if its in neutral also? It is very random it will run 10 hours plus and not die then some times it will die 3 or 4 times in a row in less than five minutes then run fine the next ten hours! Could a diode cause this? I've tested all my relays checked all my safety switches and traced all my wiring and have still yet to find the problem?
