Farm trailer bed replacement
/ Farm trailer bed replacement #1
lhfarm
Central Indiana
NH TC40DA
Not sure this is the right forum, but need some advice on repairing an all metal 4x8 trailer. The diamond plate is rusted out in the front, along with the 2" channel that ties it to the frame. Do I need to completely remove the old floor or can I just replace the front channel and repair the rusted front, and drop a new sheet of diamond plate?
This is a farm trailer and doesn't need to be road worthy. It just needs to haul wood and yard waste.
Thanks,
/ Farm trailer bed replacement #2
If you've got a torch or plasma, you could probably just cut out the cancer and weld in new... Steve
I would look close at the tongue though, make sure the rust hasn't gone too far -
Sadly, no torch or plasma here. Just looking for a quick fix so I can start hauling firewood. I'm behind!
Thanks,
/ Farm trailer bed replacement #4
What do you think about cutting that channel out with a zip disc, and replacing it with say 4" x 4" angle iron?
/ Farm trailer bed replacement #5
quick fix?
what abot a sawsall with metal blade.. or angle grinder and cutt3r wheel.
for emergency. just toss plywood int here and roll with it.
That would be easier, but they used the 2" channel to raise the bed off the frame. Not sure why.
quick fix?
If I can get the front re-welded, I may just do that.
Thanks,
/ Farm trailer bed replacement #7
I was thinking the 4" x 4" angle may get you out to some iron that was worth saving, also support the plywood inside the bed. What about spacing the angle iron up?
/ Farm trailer bed replacement #8
if you can't re weld. drill and bolt. better than nuttin. and it's not going onthe road anyway.
This is getting me thinking - what I needed. I'll head down to the barn tomorrow and see what I might be able to do quickly. My welding is shaky too, so simpler is better.
Thanks,
/ Farm trailer bed replacement #11
Thanks,
luckily it's a farm job.
grind the metal clean in a couple spots to tack.
not like it needs to survive 75mph.
Did a quick measurement and a 4" angle would get me to solid metal on the side and floor. Think of getting a piece of 2" channel and welding that to the frame, then the put the angle on top of that.
How thick does the angle need to be? Stated another way, what should I ask for at the steel store?
Thanks,
/ Farm trailer bed replacement #13
That's how I would do it.;)
My steel book shows 4" x 4" structural angle come in 1/4, 5/16, 3/8, 7/16, 1/2, 5/8, 3/4-inch. I'm no engineer, but that small of trailer I would think 1/4 to 3/8-inch would be good enough.:confused3:
Finally got the repairs made. Just need to drop a 4x8 of 3/4" plywood and I'm ready to haul firewood! As suggested, used some 4" angle on top of the 2" channel. Used tools I had to cut away old metal. I've defined this as a UBF job - ugly, but functional, so no closeup shots of my welds.
PALLET OF HOSE REELS (A68842)
PALLET OF HOSE...
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
2006 Hummer H3 4x4 SUV (A64557)
2006 Hummer H3 4x4...
2022 USA Attachments EB-618 18in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
2022 USA...
2018 CHEVROLET 3500 SILVERADO CREW CAB PICKUP TRUCK (A66091)
2018 CHEVROLET...
2006 KENWORTH T800 TRIAXLE (INOPERABLE) (A67714)
2006 KENWORTH T800...
