Farm Tractor won't start
   / Farm Tractor won't start #11
If you have those cable ends that have two bolts that tighten onto the cable, it's a good idea to put a bit of metal between the bolt ends and the cable instead of just screwing down onto the cable ends. On my boats, I always used to cut some copper from copper water pipe, and let the screws push down on that.
D, I should have done that, when I added the cable ends with the two bolts, I did clean and scraped the ends with a wire brush, but still a NO START Problem. I did purchase new cable and a different cable end. The old connector ends with no metal/copper had me going crazy. The new ones work!!
Thanks again to all who sent their advice, and ideas-they worked! However, now I have a new problem: my 1995 F450 dump truck-the dump goes up, but not down.
I will post under Hydraulics.
   / Farm Tractor won't start #13
...I did clean and scraped the ends with a wire brush, but still a NO START Problem. I did purchase new cable and a different cable end. The old connector ends with no metal/copper had me going crazy. The new ones work!!
Philip38 ... Thanks for coming back to report the solution... It bugs me no end to have a problem with no solution. Your ending post make this thread helpful to someone with the same problem.
   / Farm Tractor won't start #14
Glad you were able to get her going
2002 Kendall 12ft Enclosed T/A Trailer (A50324)
2002 Kendall 12ft...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2016 GMC Terrain SLE1 SUV (A50324)
2016 GMC Terrain...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
Quick Attach Pallet Forks (A47384)
Quick Attach...
