Farm Tractor won't start
   / Farm Tractor won't start #1
Phillip38
Branson F4350
New battery & tested cables 12V Plus, will start quickly with power pac attached to cables on the battery; have cleaned the cable terminals, and are very tight on battery posts. What is goiing on? Have taken off cables from
battery posts and re-tighten-several times. Tractor battery check on instrument panel goes to Positive, then I turn the key starter, and click, then the battery check positive goes down to negative-shows negative until I again move the cables at the battery posts. Do I need new cables, or what?
   / Farm Tractor won't start #2
MoKelly
Super Member
Jefferson County, Mo, ... about 35 miles out of St
Bobcat CT235, Bad Boy z-turn, Suzuki Vinson 500 and F-150
Welcome from Missouri.
You very well may need new battery cables. Some can get messed up inside where it is impossible to detect.
Also, have you checked where the cables are attached to the tractor body to make sure it’s clean and well connected?
Good luck.
MoKelly
OP
P
Phillip38
Branson F4350
Thanks M, I appreciate your response-I will check and see where cables are connected to tractor body, and make sure "it's clean and will connected"
   / Farm Tractor won't start #4
jaxs
Elite Member
North Tx
841 ford,MF65,Cub Lowboy,,Ford 600
Could be as simple as dead battery. You say battery is new but it's possibly run down or defective. Fully charged a good battery should have 12.7 volts,maybe more but 12 volts isn't enough to crank anything. Charge it,test it and try it agin.
   / Farm Tractor won't start #5
KWentling
Veteran Member
Rozet, Wyoming
Kubota BX22, Kubota ZD21, Kubota M7060
This plus check your voltage at the starter while attempting to start the tractor. That can aid in determining if you have a cable problem or battery problem by the difference compared to at the battery voltage.
   / Farm Tractor won't start #6
denchen
Boston England
Iseki 2140
It sounds like a dud battery. The simple test would be, is to get another battery from somewhere, and try to crank. If it goes, then it's simply a dud battery, irrespective if its a new one. If the symptoms' are the same, then it's time to do more research.
OP
P
Phillip38
Branson F4350
Thanks to J, K, and D for your advice, I will check all of it out-Thanks again.
   / Farm Tractor won't start #8
hosspuller
Veteran Member
Piedmont Triad, NC
Didn't intend to have a Deere fleet - it just happened 310C, F915,102, 5200 & 5065E
OP
P
Phillip38
Branson F4350
J, I just recently purchased the battery at COSTCO (Internstate Batt}, my multimeter registers 12.9 V.
K, I think I do have a cable problem, will check check voltage at the starter.
D, I may have purchased a bad battery, I may have to return the batt. and get
a new one.
OP
P
Phillip38
Branson F4350
H, I think you are right, I may have bad cable ends, I added these ends some time
back, and, although I did clean them good, and scraped them with a metal brush, the connectors may be bad. I will purchase new cables, will let you all know after I replace the older cables. Thanks!
