Farm Trac 665 DTC Fuel Solenoid
   / Farm Trac 665 DTC Fuel Solenoid #1
I Piddle
Western Maryland
Farmtrac 665 DTC
I am trouble shooting the ignition switch and trying to trace the wire form the fuel solenoid. Could someone direct me to the location of fuel solenoid? All Farmtracs should have a similar location for the solenoid, if you don't have a 665 as a reference.
   / Farm Trac 665 DTC Fuel Solenoid #2
The shut off solenoid is just above where the steel lines hook up to the inj pump..
Good luck
Thanks for the info. I went though the parts manual and I couldn't find it. I just needed someone to point me in the right direction. My tractor is out at my home place that I bought from my parents years ago. I just wanted to make sure I am able to recognize it then I get out to the tractor. I may have to drift start it and I wanted to make sure it has fuel to run. Last week I started the tractor up and drove it out of the shed. I shut it off then it wouldn't start. I thought maybe it was the ignition since it started right up in the shed and the battery read 12 plus volts. I need to check out the wiring and fuses. Just in case I can't get it figured out right a way I would like to use the tractor a little until figure it out.
   / Farm Trac 665 DTC Fuel Solenoid #4
If ur still having questions, snap a pic of your breakdown and I’ll point it out..
2025 K2223 UNUSED Double Garage Metal Shed (A53117)
2025 K2223 UNUSED...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
1261 (A50490)
1261 (A50490)
Guard Rail Pieces (A51692)
Guard Rail Pieces...
