Farm System tractor
/ Farm System tractor #1
Maka
Granbury, TX
1620 Ford with loader
Hi Gang. I have a gentleman who bought a Chinese tractor called a Farm System. He said it was from 1994. He needs an oil filter for it and I have never heard of this tractor. I know it is Chinese, 2 cylinder and probably Yang Dong and is model J285T. Anyone know where a oil filter can be had.
The filter is about 3 1/4" long has about an in diameter of about 1 1/2 on the hole. There is diamond imprint with some Chinese writing on it but no part number.
Sorry for the lack of info but I don't have the machine and am getting info from customer.
Thanks,
maka
/ Farm System tractor #2
I'm unaware of any YangDong 2 cylinders, and anyway - a Y285 sounds awful small - I'm guessing 16hp or less. But it might be a TY290X, TY295, or XN2100. The info stamped on the engine plate is important. Is any of it still legible?
//greg//
I actually had him read the engine plate to me over the phone and it is definitly J285T.
Thanks,
Bob
/ Farm System tractor #4
OK, first 85mm two cylinder I've run across. Without any more info from the engine plate, I'm can only speculate. But we might be talking Jiangxi JiangLing; what's suggested to be a Chinese Mahindra. See Tractor (FS180) - China Tractor in Tractor and FS180 Tractor
Sorry that doesn't answer the original question, but it might help get pointed in a more definite direction
//greg//
OK, he said it is a Jiangxi. Any filter sound like what I described?
Thanks,
Bob
/ Farm System tractor #6
Well, you only gave two dimensions, so that didn't tell me cartridge-type or spin-on. Except for the inch and a half hole, I'd have guessed spin-on. But 1.5" an awful big thread size, and for a spin-on that may be problematic.
Any replacement filter is likely going to be metric anyway. Think the customer can be a bit more specific?.
//greg//
This is drop in not threaded he said. It sits in a canister. Sorry guys for this but he is giving this info.
Thanks,
Bob
/ Farm System tractor #8
OK, We might get this with time. My KM454 uses cartridges. One is (and these are approximate) about 83mm wide, 119mm tall, and the top/bottom holes are about 39mm. Another is about 68x84x34. The third one isn't even close
These two are as close as I have that are near your estimated 1.5" center hole (that's the same as 38.7mm).
Moreso than with spin-ons, all dimensions of a cartridge filter must be exact. You probably already know why - because both top and bottom holes must seal against fixed 0-rings.
//greg//
Thanks Greg. I will send the info as a PM. I am going to have t he guy bring to me so I can take measurements and get it done. I don't want to take to much time from good folks here trying to help so I will have him drop it in to me and expedite the process.
Thanks so much.
Maka
/ Farm System tractor #10
You could just take it into NAPA or any petroleum distributor and have them match it up.
