Farm System tractor
   / Farm System tractor #1
Maka
Veteran Member
Granbury, TX
1620 Ford with loader
Hi Gang. I have a gentleman who bought a Chinese tractor called a Farm System. He said it was from 1994. He needs an oil filter for it and I have never heard of this tractor. I know it is Chinese, 2 cylinder and probably Yang Dong and is model J285T. Anyone know where a oil filter can be had.
The filter is about 3 1/4" long has about an in diameter of about 1 1/2 on the hole. There is diamond imprint with some Chinese writing on it but no part number.
Sorry for the lack of info but I don't have the machine and am getting info from customer.
Thanks,
maka
   / Farm System tractor #2
I'm unaware of any YangDong 2 cylinders, and anyway - a Y285 sounds awful small - I'm guessing 16hp or less. But it might be a TY290X, TY295, or XN2100. The info stamped on the engine plate is important. Is any of it still legible?
//greg//
I actually had him read the engine plate to me over the phone and it is definitly J285T.
Thanks,
Bob
   / Farm System tractor #4
OK, first 85mm two cylinder I've run across. Without any more info from the engine plate, I'm can only speculate. But we might be talking Jiangxi JiangLing; what's suggested to be a Chinese Mahindra. See Tractor (FS180) - China Tractor in Tractor and FS180 Tractor
Sorry that doesn't answer the original question, but it might help get pointed in a more definite direction
//greg//
OK, he said it is a Jiangxi. Any filter sound like what I described?
Thanks,
Bob
   / Farm System tractor #6
Well, you only gave two dimensions, so that didn't tell me cartridge-type or spin-on. Except for the inch and a half hole, I'd have guessed spin-on. But 1.5" an awful big thread size, and for a spin-on that may be problematic.
Any replacement filter is likely going to be metric anyway. Think the customer can be a bit more specific?.
//greg//
This is drop in not threaded he said. It sits in a canister. Sorry guys for this but he is giving this info.
Thanks,
Bob
   / Farm System tractor #8
OK, We might get this with time. My KM454 uses cartridges. One is (and these are approximate) about 83mm wide, 119mm tall, and the top/bottom holes are about 39mm. Another is about 68x84x34. The third one isn't even close
These two are as close as I have that are near your estimated 1.5" center hole (that's the same as 38.7mm).
Moreso than with spin-ons, all dimensions of a cartridge filter must be exact. You probably already know why - because both top and bottom holes must seal against fixed 0-rings.
//greg//
Thanks Greg. I will send the info as a PM. I am going to have t he guy bring to me so I can take measurements and get it done. I don't want to take to much time from good folks here trying to help so I will have him drop it in to me and expedite the process.
Thanks so much.
Maka
   / Farm System tractor #10
You could just take it into NAPA or any petroleum distributor and have them match it up.
Hydraulic Excavator Thumb (A57454)
Hydraulic...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
2013 Nissan Sentra Sedan (A56859)
2013 Nissan Sentra...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
INOP/NON-RUNNING 1999 Isuzu NPR-HD Cab and Chassis Truck, VIN # 4KLC4B1R5XJ001370 (A57453)
INOP/NON-RUNNING...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
