Farm Pro 2420 Maintenence
   / Farm Pro 2420 Maintenence #1
mikeridge
wadsworth, ohio
Farm Pro 2420
Greetings,
I posted about a farm pro 2420 that was on my property when I bought it and wasn't sure what to do. Hadn't been started in a long time and I don't know about diesels. Long story short, with the help of my father and brother in law we were able to successfully jumped the tractor and get it started and was running fine.
Now I will be draining all of the fluids including the oil, transmission fluid, and diesel with new. I went to my nearest NAPA store and got a new battery, oil filter, fuel filter and air filter.
Does anyone else have any suggestions on what I should do to keep this tractor running and maintaining it well?
Also when I got home from Napa with the new battery I tried to jump the tractor with it but it wouldn't turn over. The battery I got from Napa is the 7237 commercial battery with 950 cca. The tractor would not turn over with the new battery any thoughts on this?
Any help and suggestions would be appreciated. Thanks!
Mike
   / Farm Pro 2420 Maintenence #2
Definitely change the engine oil. Other than that, I wouldn't bother with the other fluids as long as they are full and look clean. If they are low or seem contaminated, change them. When you change the engine oil be sure to change the fuel pump oil too. These tractors are not well weather-proofed and water can get in the fluids if they are left out. The oils will look milky if that happens, definitely change them in that case.
Most likely cause of the starter not turning over is a poor ground. Second most likely is a poor battery cable. When you jumped it before did you just put jumper cables on the positive terminal and on ground, and turn the key? If that worked it means your starter is fine, as is your key switch and clutch switch, three common culprits. The reason that worked and your battery doesn't is that you bypassed the cables, which are probably loose or dirty.
The best way to keep this tractor running is to post here frequently.
Thanks for replying.
I'll check the other fluids just to be safe and change if needed.
As far as starting it, we used two trucks and two jumper cables to start it. My 2013 Sierra wouldn't start it just by it self so we hooked up two trucks with jumper cables. It then started right up. I bought the new battery, one that I read is the replacement for it and it acted as if it didn't have enough juice to fire for it to turn over.
Mike
   / Farm Pro 2420 Maintenence #4
If it takes THAT much battery to get it to crank, it's most likely cables/connections or the starter itself. The battery you described should be plenty strong for that size tractor.
   / Farm Pro 2420 Maintenence #5
^ +1. I have the same size battery (950 CCA) and it is plenty strong for that tractor. Check your ground connection to the frame - the factory is notorious for leaving a thick layer of paint under that ring terminal. Also, the factory cables corrode internally after a few years - the ends may look okay, but the guts of the cables turn to dust.
   / Farm Pro 2420 Maintenence #6
So what's puzzling to me is the part about two batteries working. In an electrical circuit, power is equal to voltage squared divided by resistance. The more resistance you have, the less power you get. This is why faulty cables are a problem, too much resistance means you can't get enough power. Adding another battery in parallel -- red to red, black to black --
doesn't increase the voltage, so if the resistance stays the same the power stays the same.
If they are hooked up in series -- red to black -- then you get 24 volts, and with the same resistance you'll get four times the power. Which would probably result in fuses popping all over the place when you turned the key on.
The thing about high resistance is it's often intermittent -- moving a cable around improves the connection, it's like the old TV's with rabbit ears. Until there is evidence to the contrary I'm going to hypothesize that having two batteries wasn't what made it start, it was moving the cables around.
   / Farm Pro 2420 Maintenence #7
^ I absolutely agree, except for the popping of fuses.
   / Farm Pro 2420 Maintenence #8
Firts you need to see which 2420 you have, most were 2 cylinder, at the end of their run they went to 3 cylinder. They were rebranded Jinma 200 tractors, the jinma manual shows both type engines. I can email you a PDF copy of the manual if you need it, I got one online for free.
   / Farm Pro 2420 Maintenence #9
I have a FarmPro 2420 380 Series 2004, my problem is I never receive a manual when I bought this tractor I don’t know where to check the hydraulic fluid or drain the hydraulic fluid or check the transmission fluid. If you could help me with this, it will be appreciated. If you could email me a copy of the manual it will be appreciated if you have one. Thanks,
   / Farm Pro 2420 Maintenence #10
Jhenley,
Your HF dipstick is behind the seat on top of the lift arm housing between the bases of the lift arms. Mine is a square pipe plug and has a little u-shaped breather tube soldered in it. Tranny dipstick is on top of tranny and is also a square pipe plug. My 2420 is late 2003 with TY290X 2 cylinder diesel that I bought new in 2004.
BTW, make sure to check the oil in the injector pump before you operate it. Change the oil in the injector pump every time you do an engine oil change. I use engine oil and to fill it to the proper level, add oil until it overflows from the 1/4" overflow tube held on by a slotted bolt head on the side of the IP. This overflow tube/slotted bolt head will be behind the primer pump plunger on the side of the injector pump.
   / Farm Pro 2420 Maintenence #11
Jhenley,
Thank you very much that been very helpful, you have any idea where I can get a Manual for the Farm Pro 2420 ? It is a good running Tractor I like to keep it that way. Again Thanks.
   / Farm Pro 2420 Maintenence #12
Thanks for the advice, my FarPro 2420 is a 2004, 2 cylinder. Please email me a PDF copy of the manual that will be appreciated Thanks, Jhenley144@gmail.com Thanks,
   / Farm Pro 2420 Maintenence #13
Mice chewed up ours or I'd scan a copy of it. lol It was pretty useless though overall.
   / Farm Pro 2420 Maintenence #14
Your best bet of getting manuals will be to contact Tommy at AffordableTractorSalesCo.com. I think I have read in older posts that they have manuals available and stock a lot of the parts for these FarmPro/Jinma tractors.
   / Farm Pro 2420 Maintenence #15
Thanks,
   / Farm Pro 2420 Maintenence #16
Thanks for the previous information on checking the hydraulic fluid on my FarmPro 2420 2cylinder 380 series, do anyone know how to adjust the PTO clutch on this Farm Pro 2420, I cand engage the PTO, but it will grind when I try to engage it. I assume some type of adjustment need to be made, the grinding do stop after the PTO is engage. Can someone please help me with this issue. Thanks,
   / Farm Pro 2420 Maintenence #17
I just did this adjustment on my 284. I'd think your 2420 would be about the same.
Here's a link to a general how-to: John's Jinma Tractor Clutch Adjustment
Here's a link to another, with detailed photos: Keno Tractors Clutch Adjustment PDF
The PTO adjustment on my clutch was extremely sensitive -- I only needed to turn the adjusting nuts about one flat (1/6 of a turn) in order to get it dialed in. Turn too far one way and the PTO clutch slips; too far the other way and it grinds. I had the clutch serviced at a tractor dealer about 10 years ago and they experienced the exact same sensitivity while testing the PTO on a dyno.
Good luck with it,
   / Farm Pro 2420 Maintenence #18
Good luck with it,
Thanks for all your information. I got the tractor running correctly today no more grinding when the PTO is being engaged. Again thanks 🙏
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
UNUSED FUTURE TBL47-47" HYD TELESCOPIC BOOM (A60432)
UNUSED FUTURE...
2022 John Deere 5055E (A60462)
2022 John Deere...
2018 VOLVO VNL TANDEM AXLE DAY CAB (A59905)
2018 VOLVO VNL...
