fan belt
/ fan belt #1
kroger
Hamburg Arkansas
Hi I Farm Pro 2420 I need a fan belt but it want go pass the pulley and frame do I need to remove the pulley to put on the fan belt
Thanks
/ fan belt #3
I don't understand. After loosening the pivot bolt on the alternator, the belt should come loose from both pulleys. At that point you should be able to simply slip the belt over the fan blades. Depending upon how small the belt is, you might have to do it one blade at a time. But that's how it was put on there in the first place.
//greg//
/ fan belt #4
This will solve your problem. Vibration Free Link Belt It's better than a regular belt.
I wholeheartedly agree. It will be the last belt I bought. I even put one on the Mustang skid steer.
Welcome to the 21st century! :thumbsup:
/ fan belt #5
I am with Greg. It will go, you just have to hold your tongue right.
Chris
/ fan belt #6
I' m alongside Greg, just be sure to watch for bending the rad. fins when pulling belt past the fan tips. Some equipment is very easy to slide the belt past, bending fins on the Rad. causes several other problems later. Jy.
/ fan belt #7
Just one of the sweet benefits of the linked belt that you gentlemen are fighting about - no need to risk damaging your radiator and skinning your knuckles. The linked belt is not new. Been in industry for many years.
Power transmission, motion transfer and conveying components from Fenner Drives
I keep forgetting the old adage: "You can bring a horse to water, but you can't make them drink it". :D
/ fan belt #8
My belt broke today and it was shreaded does any know what lenght it is so i can go to a local auto parts and get one?
thanks
/ fan belt #9
thanks
You did not say what tractor?
Best way I have found is measure the width of the pulley then wrap a piece of string around as the belt would go and tie it off. Remove and now you have a templet to take with you.
Chris
/ fan belt #11
His profile lists a 2003 FarmPro 2420, but no engine specs. Maybe TY290?
/ fan belt #12
Hey Kroger,
Get a Lin-Belt.The old belt want go between the crankshat pully and the frame.The Farmpro2420 has got the be the worst design in the world just to change a fan belt.There is no room to do anything.All you need was maybe 1/2 inch more room but no.
The link belt is the answer.
Mike
/ fan belt #14
I have never had my hands on one of those belts, but some of you have. The site said that a person could easily make matched sets of belts. Do you guys get the impression that the belts would indeed be well matched if the same number of links are used per belt?
/ fan belt #15
I have them on my equipment, and have experience with them in an industrial setting. You can match sets with approximately 1/64" tolerance.
They have been around a long time and are very widely known.
High Performance Composite Belting - PowerTwist Plus, NuTLink and SuperTLink - Fenner Drives
2015 Kawasaki Prairie 400 ATV (A64557)
2015 Kawasaki...
KMC 14' FIELD CULTIVATOR (A64278)
KMC 14' FIELD...
Sunflower (A64557)
Sunflower (A64557)
2020 Inifiniti Q 50 Sedan (A64557)
2020 Inifiniti Q...
Small Cowboy Statue (A64557)
Small Cowboy...
2154262019 FAE UMLV SSL- 150VT HYD MULCHING HEAD (A65053)
2154262019 FAE...
