Fan Belt Replacement.
   / Fan Belt Replacement. #1
BADDBOYY21
Pittsburgh, PA
Massey-Ferguson 165 Diesel
I am planning on replacing the fan belt on my 165 this weekend. I do not have a manual as of yet. Can I replace the belt by loosening the generator or do I have to remove parts?
Thanks in advance.
Shawn
   / Fan Belt Replacement. #2
You should be able to loosen & push the generator/alternator forward. Slip the belt off the generator pulley and over/off any other pulleys and then over the fan. A quick look at the fan belt and its path will determine if any parts need to be removed. It may be a difficult path but there should not be any parts needing removal. Google your tractor model/type and see if an owners manual is available on the web for viewing.
Thanks! By looking at it, I figured I could do it without removing anything.
Had to remove the radiator shroud to get the belt over the fan.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2019 Chevrolet Express 2500 Cargo Van (A51692)
2019 Chevrolet...
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2017 KENWORTH T680...
Travel Trailer (A51694)
Travel Trailer...
