Fan Belt Replacement.
   / Fan Belt Replacement. #1
BADDBOYY21
Pittsburgh, PA
Massey-Ferguson 165 Diesel
I am planning on replacing the fan belt on my 165 this weekend. I do not have a manual as of yet. Can I replace the belt by loosening the generator or do I have to remove parts?
Thanks in advance.
Shawn
   / Fan Belt Replacement. #2
You should be able to loosen & push the generator/alternator forward. Slip the belt off the generator pulley and over/off any other pulleys and then over the fan. A quick look at the fan belt and its path will determine if any parts need to be removed. It may be a difficult path but there should not be any parts needing removal. Google your tractor model/type and see if an owners manual is available on the web for viewing.
Thanks! By looking at it, I figured I could do it without removing anything.
Had to remove the radiator shroud to get the belt over the fan.
2019 Komatsu D51PXi-24 Crawler Tractor Dozer (A51691)
2019 Komatsu...
2016 Kubota RTV X900 (A50123)
2016 Kubota RTV...
2020 INTERNATIONAL LT625 SLEEPER TRUCK (A53426)
2020 INTERNATIONAL...
(10) 24' Free Standing Panels (A50123)
(10) 24' Free...
2018 FREIGHTLINER CASCADIA TANDEM SLEEPER TRUCK (A53426)
2018 FREIGHTLINER...
2013 Kalmar Ottawa S/A Yard Truck (A51692)
2013 Kalmar Ottawa...
