Fan Belt Replacement.
   / Fan Belt Replacement. #1
BADDBOYY21
Pittsburgh, PA
Massey-Ferguson 165 Diesel
I am planning on replacing the fan belt on my 165 this weekend. I do not have a manual as of yet. Can I replace the belt by loosening the generator or do I have to remove parts?
Thanks in advance.
Shawn
   / Fan Belt Replacement. #2
You should be able to loosen & push the generator/alternator forward. Slip the belt off the generator pulley and over/off any other pulleys and then over the fan. A quick look at the fan belt and its path will determine if any parts need to be removed. It may be a difficult path but there should not be any parts needing removal. Google your tractor model/type and see if an owners manual is available on the web for viewing.
Thanks! By looking at it, I figured I could do it without removing anything.
Had to remove the radiator shroud to get the belt over the fan.
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A53473)
2016 Ford F550 4x4...
2022 Club Car Tempo Electric Cart (A51694)
2022 Club Car...
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
2013 Freightliner M2 106 Water Truck (A53117)
2013 Freightliner...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
Ford Super Duty FX4 Pickup Truck Bed (A51692)
Ford Super Duty...
