Factory wheel weights were too expensive!
   / Factory wheel weights were too expensive! #1
keeney
Minnesota
JD 4100 HST
When I put the snowblower on the front of my 4100, it was recommended to add 120lbs of weights to each rear wheel.
This wouldn't really help take any weight off the front wheels, but I suppose it improves stability and adds traction. I haven't had any traction issues without weights, but I thought I should look into getting some in case I ever do find myself needing more traction.
I was very surprised by how expensive the JD factory wheel weights are!
I decided to make my own. I used 25lb weight plates. About 11 inches diameter x 1.5 inches thick. They cost 40 to 50 cents per lb at a used exercise equipment store.
(continued)
I bored four 5/8" dia. holes on a 10.0" dia. bolt circle in each weight.
After painting they are mounted with ½ x 8" carriage bolts. I used the carriage bolts because they don't leave any sharp edges sticking out of the wheel to snag on as you walk by the parked tractor in my crowded garage.
(continued)
I was going to match the 10.5" circle of holes already in the wheel for the factory weights, but the diameter of the plates was slightly too small for that. Instead I ended up slotting the holes in the wheel to accommodate the 10.0 dia. circle of holes on the weights. I didn't want to remove the weights just for a photo, but in this close-up of the nut on the inside of the wheel you can see that the hole is slotted.
(continued)
A stack of 4 on each wheel adds 100 lbs. and is just flush with the edge of the tire.
With longer bolts you could fit 125lb or maybe 150lb on each wheel this way. If the wheels were flipped to the wide position, 5 plates should still be recessed in the wheel.
I think the overall look is not too bad and was a lot cheaper than the factory weights.
- Rick
   / Factory wheel weights were too expensive! #5
Looks good. Thats what I am going to do with my Ingersoll. BTW what size wheels are on that thing? I was going to use 45lb plates on mine, but maby that would be to big. I have 16" wheels on mine.
   / Factory wheel weights were too expensive! #6
Like you, I was really set back by the cost of the JD factory weights. I ran across a set-up on the Tractor Hacker Page that is what I'm going to try to use with my 4400. You can see it <A target="_blank" HREF=http://www.mgsweb.com/tractor/hacker/wweight.htm>here</A>. The advantage I see to this set-up is the ease with which weights could be put on and removed. While the mounting plate could remain attaced all the time, you could add or reduce weight very easily. Our local Wal-Mart has some 45# weights that I'm going to use that have a 2" center hole and have cast in "handles" that would facilitate adding/removing weight even more. These weights are around $19.00 for the 45# weight. I figure that with fabricating the base plate and buying 10 of the weights (enough for 5 on each side), I'll still have less than 1/3 of the cost of the JD weights tied up in it.
Hoss
   / Factory wheel weights were too expensive! #7
Keeney; This looks good and I think I will do the same and just use 50 pound universal plates from my current weight system. I will also look into making up some plates/brackets much like the Kubota that is pictures in the other message. That looks pretty good, but then again, so does your design.
nuru
s1120,
The wheels are 15" with the turfs on the JD 4100 (other tire types use different wheels).
The center area had about 12 inches of space. I was hoping to find some plates of about 11.5 inch diameter, but the ones I ended up using were 11.0 inch diamater.
- Rick
CVHoss, Nuru,
I looked at the design of having a base plate with center post, but I wanted to avoid having the plates be loose to rattle around. I wanted them bolted them on tight. This design does however share some of the same knuckle-busting attributes of mounting the factory-style weights. You have to hold 100 or 125lb of stuff up on the wheel in the right place while getting the bolt in place and starting the nut on the other side of the wheel.
In my case, they will only come on and off once per season. On for winter plowing and snow-blowing, and off for summer mowing, so its not a big deal if they take half an hour to put on or take off.
- Rick
   / Factory wheel weights were too expensive! #10
I got a seat of rear wheel weights from a john deere 7700 combine. The bolt patern matched to my JD R-4's I gave $90 for the pair. There atleast 150LB each way to heavy one person to put on.
2014 CHEVROLET SILVERADO (A50854)
2014 CHEVROLET...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Allis Chalmers Disk (A50515)
Allis Chalmers...
INGERSOLL RAND 100KW GENERATOR (A50854)
INGERSOLL RAND...
(INOP) CATERPILLAR 416B BACKHOE (A50459)
(INOP) CATERPILLAR...
2013 DODGE RAM 1500 FLATBED TRUCK (A51243)
2013 DODGE RAM...
