factory loader #YFL800
/ factory loader #YFL800 #1
Whiskey
Platinum Member
Florida
YM 187 Yanmar / JD 790
ok guy's
Ive been hunting this little beast for a while with no luck and was thinking the only route left was after market loaders.
Everyone I've talked to has told me the factory loaders that Yanmar sold with there American model tractors were good loaders and worth the time shopping for one. Well, I poped onto E-bay this morning and low-and-behold there one is, but it has some damage to it.
Do any of you Yanmar guys out there, dealers or private know of a YFL800 loader for a YM187 tractor just sitting around waiting to be sold to me /forums/images/graemlins/grin.gif
Thanks
Whiskey
/ factory loader #YFL800 #2
Hello Whiskey, I was in the same position as you, except it was a 226D. Searched high and low, none to be found.I guess once you have a loader, you don't want to part with it!! The stuff that I did find was been used to the point of selfdestructionThere are some very good aftermarket loaders available. I wouldn't be to worried about less capability or quality than the original loader. The only thing that none of the aftermarket loaders have is a bracket to attach the main attach point from the loader(what is tied to the transmission and frame) to the rear axle,what is what yanmar did on most, if not all of their loaders. This is pretty easy to make yourself (or have made) Both Allied and Koyker make nice loaders that would do a fine job
thanks Pete
/ factory loader #YFL800 #3
The YFL800 was built to mount on the YM226.The YFL650 & YFL675 were designed for the YM187.
Peter & Lens12
Hey guys thanks for the response, Peter the Allied & Koyker are probley top on my list of after market loaders. I think I will be looking that way soon, this was just one last effort in looking for the factory loader.
Len12 thanks as always for the proper model # on the loader you just saved me from bidding on the wrong loader for my tractor. I checked this morning and it is up to over $200 and that was all I was willing to bid on it anyway.
so-anywho if anyone comes across a YFL650 or YFL675 that mayne for sale drop me a note.
Whiskey
/ factory loader #YFL800 #5
Where was it for sale?
/ factory loader #YFL800 #7
Hey Whiskey iI have a Yanmar loader made in Canada, Its stamped Yanmar. I traded for it to go on dads YM3000 but he and I decided to build one becuase the quicktach lader is wider than what we like. Were used to how narrow an indusstrial loader is. My loader looks exactly like the one shown on Ebay. Its a straight loader, no welds or cracks, i didnt get the bucket valve or dump cylinders with it. It was owned by Uhaul for maintenance. Id sell it for 250 or trade it for something. Mesure the holes on the bottom of your tractor where the quicktach mounts, Ill measure on mine. Best reguards Taylor Lambert
Taylortractornut:
Hey, yes i'm interested in your loader, see if you have a plate on it or stamped in the metal somewhere the #YFL600 or YFL675. When you said U-hall I know they carried a lot of YM336's for renting at one time and I don't think the loader for the 336 will fit my YM187.
When you said mesure the holes are you asking from one side of the tractor to the other or between each hole on one side?
Whiskey
/ factory loader #YFL800 #9
Ill get the numbers off the plate, Measure the hole on the botom of the tractor where the quicktach sub frame is mounted.There should be 4 holes. Ill get all the measurements and try to get a photo of it. Ill measure it today Where are you located Im in Northern Mississippi
Talyortractornut:
Here's what I came up with, mesurements were taken with just a regular tape but as close as I could get.
Whiskey
hummm..pic didn't post. second try
well, pic is not wanting to post so left to right is 2 3/8" center to center, top to bottom is 1 6/8" center to center
Whiskey
/ factory loader #YFL800 #13
I looked at the tag on my loader and its says its a 1575. It 41 inches between the uprights on the loader and on the quicktach frame its 13.5 inches between the mounting plates. The lower holes are 6 inches apart. and i think 4 inches to the uper hole. What size is your tractor compared to a 3000 YM. If you decide you want it an live close enough ill even help ya mount it. Ill try to get some pictures if it stops raining long enough.
Taylortractornut:
OK, next day and I'm going to try and give you a pic, see if they have gotten the site all running smooth now
KBH 1600 Gallon Water Trailer (A64047)
KBH 1600 Gallon...
KUBOTA SVL97-2 SKID STEER (A62129)
KUBOTA SVL97-2...
(APPROX.100) UNUSED KJ 10' HD GALVALUME STEEL (A62131)
(APPROX.100)...
Arrow Quip MAN-STBR Sternum Bar (A64047)
Arrow Quip...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A63118)
2008 Ford F-250...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
