Factor 3rd function switch broken
   / Factor 3rd function switch broken #21
Have two tractors with that same switch. B26 placement is such it is easily turned off/on by your right leg. M59 has better clearance. Still the switch is plastic and kind of flimsy compared to other switches like the hazards or lights.
See metal, 16mm, led indicator, waterproof similar switches on eBay that might work. Size matters so if you could give diameter that would be helpful.
Installed small led rubber grummet mounted trailer running light for the B26 brake warning light. 3/4” hole. Very bright, obvious and installation is easy.
LED for warning lights just make sense. All this stuff is so cheap that it doesn't make sense to me to buy low price. If quality is more interesting than price, check out McMaster.com. They have been suppliers to gadgeteers, engineers, and fabricators for over a generation now. Top notch outfit and they have everything.
   / Factor 3rd function switch broken #22
McMaster catalog is one of my favorite books. Not only for the merchandise but also for the information.
2015 Ford Fusion S Sedan (A54815)
2015 Ford Fusion S...
2018 John Deere TX (A53317)
2018 John Deere TX...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A56859)
2004 Fleetwood...
2022 BOBCAT E60 R2-SERIES EXCAVATOR (A52709)
2022 BOBCAT E60...
17307 (A55853)
17307 (A55853)
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
