Fabric tractor shed
   / Fabric tractor shed #31
Looks real good to me. What cha goin' to cover it with? Probably still should have some anchors though.
Cheers,
Mike
   / Fabric tractor shed #32
Currently I have all the the foundation blocks fastened to the structure with heavy galvanized strapping, I cannot budge the thing. I have some diagonal braces in each of the corners which I can run some ground anchors through for a bit of extra security or I can add some more blocks.
Cover? I went down to the local HF and bought a 28x39 9 mil tarp. The plan to fasten should be on the order of greenhouse film.
   / Fabric tractor shed #33
We moved into our home June 2017. The previous owner had a 14x24 ShelterLogic with a gravel floor. I swapped that for a concrete pad this summer. D742C93B-3F04-4291-94E4-7E86D22FD1BB.jpegEDA0EF49-10F9-4394-8FA3-DDCABE036FC6.jpeg546CF8DD-28E3-4238-878F-132A516AF45A.jpeg
   / Fabric tractor shed #34
   / Fabric tractor shed #35
Thats such nice wood framework to just throw a tarp over it. Do you plan on puting metal on it?
   / Fabric tractor shed #36
Yes there is a future plan to have the building be permanent on a concrete pad with proper sheeting. I used nothing but screws so disassembly is possible without damaging anything. The only things not reusable are the tarp and the exterior roof ribs as I put adhesive on the ribs to bond them to the tarp.
   / Fabric tractor shed #37
I started my shelter logic 12x20 garage in a box the other day. Had an hour of daylight to get to here. Hopefully get it the rest of the way this weekend If the rain holds off. Tractor supply had it on sale for $330. I’m not initially impressed with the size/thickness of the cover that came with it. I figure I’ll get a year out of it. IMG_9626.JPG
46'x25' Metal Garage (A53316)
46'x25' Metal...
2005 Sterling L7500 Fuel and Lube Truck, VIN # 2FZHATDC95AV42993 (A54865)
2005 Sterling...
John Deere 2955 (A53314)
John Deere 2955...
Case Axial-Flow Combine Wheels NO RESERVE (A55301)
Case Axial-Flow...
