F935 transmission fluid change/ level not showing on sight glass
   / F935 transmission fluid change/ level not showing on sight glass #1
canucklehead
frozen Canada
1979 Ford 1500, Toro 455D 10' mower w/ Renault diesel,
I changed the filter & TDH fluid on my F935. Manual calls for a capacity of 4.6 quarts, and to check level on sight glass. I'm sure I removed a lot more (it's been awhile since I did fluid change), and I added at least 5 quarts and never saw anything on the sight glass. What's the deal ?
the JD Low visc fluid is kind of clear and the fluid I took out was more like tranny fluid reddish color. Is it hard to see the clear fluid in the sight glass?
I know the reservoir under the seat where I add fluid is totally empty, and I assume it's supposed to be like that, otherwise there's too much fluid (??)
   / F935 transmission fluid change/ level not showing on sight glass #2
I did the same thing using JD low visc and had to install a new tube to be able to see the oil. It's not hard to do. It's not fun either. If I remember correctly I just used a piece of new plastic tubing that I had laying around.
thanks PMSmechanic. My tube seems clear now, and before i did fluid change, i could see the old red fluid in the sight glass. I just can't see the clear stuff in it.
   / F935 transmission fluid change/ level not showing on sight glass #4
There is a hydro fluid dye sold by John Deere. Part #MT3668. Just do an internet search for it.
thanks Amvcane, good info. I have some other auto dye used by Ford.
Frustrating they make it this complicated. They use a fluid that has the level checked in a sight glass tube (instead of dipstick) and then make fluid virtually invisible so you have to buy a dye to make it visible?? aaarrghh.
I had an Amsoil 2-stroke oil that was gold in color and impossible to tell if I'd mixed gas. I put it in a designated, marked container, but always second guessed when it sat awhile. I can't believe they'd design a product like that to not have coloration to remove all doubt. So simple. aaarghh!!
   / F935 transmission fluid change/ level not showing on sight glass #6
elmer lawrence
Welcome to TBN 📣
The string you posted under is 17 years old. You will do better by starting your own post.
Richard
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2015 Ford F-550 Crew Cab Godwin 184U Mason Dump Truck (A56858)
2015 Ford F-550...
FUEL CELL (A58214)
FUEL CELL (A58214)
1999 International F-4900 T/A Cab and Chassis Truck (A56858)
1999 International...
2011 Wanco WLTC4 Towable Light Tower (A56857)
2011 Wanco WLTC4...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
