F915 injection pump
/ F915 injection pump #1
quarrymech
bethlehem ct
ford 1710 john deere F915
hey guys new to the site. i just picked up a f915 has been sitting for 6yrs ran when last parked i need to pull the injection pump. It looks simple but it seems to be i am missing something can't get it out and are they rebuildable any help would be appreciated
/ F915 injection pump #2
I have a f915. Why do you need to pull the pump? Have you changed the fuel filter & purged the lines ?
The pump has to get pulled because fuel is getting into oil. I changed fuel filter and bled it electric pump is pumping fine so basically between fuel getting into oil and the pump making no pressure that's where I am at now
/ F915 injection pump #4
Are you sure it's not just a bad or a couple bad injectors? Or is the fuel getting in when the engine just sits? On larger diesel motors injectors can wear out or go bad and pump too much fuel into the cylinder and wash the cylinder down and the fuel ends up in the crank case.
I don't know what style pump it is. If it is like the 455 you take the injector lines off and remove the 4 nuts on top and the injector pump slides out the top. I think there is linkage to remove also.
I don't even have the injector lines hooked up to the pump. I am use to way bigger diesel motors than this toy haha. I did loosen the 4 nuts on top when the lines connect to the pump I got it to move alittle. From the looks of the parts breakdown on the JD website looks like it should pop right out
/ F915 injection pump #6
There is a governor linkage under the fuel shut-off solenoid bracket that has to be disconnected.
Note the warning about shims.
hoss puller thanks for the 2 pages thats exactly what i needed to know
/ F915 injection pump #8
I work on much larger diesels as well. Sometimes people over look the simple things.
2003 VOLVO G720B MOTOR GRADER (A66091)
2003 VOLVO G720B...
Unload Auger Tube for John Deere Combine (A65640)
Unload Auger Tube...
New Holland 451 Sickle Bar Mower (A66408)
New Holland 451...
2011 Ford F150 (A66408)
2011 Ford F150...
2013 Chevrolet 3500 Dually (A62613)
2013 Chevrolet...
Manure spreader for sale / Excellent Condition / Make offer
Manure spreader...
