F22d Glowplugs dont work
/ F22d Glowplugs dont work #1
nebuniram
PNW
Yanmar F22d, Cat E70b
Guys, I am starting another thread for my glowplg issue. My dash light does not come on for the glowplugs when I turn the key to the left. I checked the light and its not burned out. I beleive I have a issue with the plugs/wiring? How would I go about troubleshooting the glowplugs?:confused: Thanks in advance
/ F22d Glowplugs dont work #2
Have you use a volt meter on the hot wire leading to the glow plugs? If so what do you see? If no voltage or way below batt voltage, problem is upstream. According to the schematic there is a control modual between the switch and glow plugs. I'd start looking for the modual and see what you find there.
Modual has 4 connections. Hot, ground, glow plugs, trigger (sig from switch).
Thanks Mickey, I will start with the volt meter and trace my way up. I saw the control module also. So I imagine you put the positive lead on the hot wire and the negative on the negative battery terminal or ground?
/ F22d Glowplugs dont work #4
Use a bungie cord with a screwdriver through the center of the key. The way you can check the circuit by yourself. I found my plugs were working, but that it took a couple minutes before they were effective.
My simples test was to hook the battery charger to the battery and turn the key. If the plugs were working it was obvious on the charger meter.
Good luck!
Well the plugs work, I took them out and hooked them up to the harness then used the fronloader frame as a ground, all three heated up and turned red. So the harness is good and so is the key switch. So why isnt the light on the dash turning on when I activate the plugs? I guess its no bigie since I now know that they work but I would still like to have the indicator. By the way guys how long are you supposed to activate the plugs before you start the engine? Thanks for all the help, maybe I can get to the bottom of why the light doesnt turn on since I know the bulb is good. Also when you press the little button on the dash that lights up all the indicator lights the only one that doesnt come on is the top one (Glow Plug) light.
/ F22d Glowplugs dont work #6
Turn the switch to the left and the light comes on, when it gets hot the light will go out, then start engine.
Danny
/ F22d Glowplugs dont work #7
What happens when you press the check light switch? This should light up all the indicator lights.
When I press the check light switch with the key in the on position but tractor not running all lights come on except for the Glowplug. When the tractor is running and I press the check light switch only the Antifreeze reservoir light and the battery fluid light come on. I already checked the Glowplug indicator light bulb and it is good. What other circuits can I check, do any of you fine gents have a schematic you could post? Thanks
/ F22d Glowplugs dont work #9
Sounds like it may be the wiring or the socket for the glow plug bulb. The bulb itself may be ok but if it's not lighting at all even with the check light's then something's going on.
Checking the socket for power was my next step. I have a schematic for the electronics on a FX/F24D, would this schematic be the same as my F22? I have attached the schematic.
  • yanmar_f24_schematic.pdf
/ F22d Glowplugs dont work #11
I have a FX24 and F18 diagram and they are essentially the same. the FX22 is probably the same. From the diagram I can not see anything the controller does, but turn the light on/off. It looks as though once key is turned to the left, power goes to the plugs. I could be wrong of course.
/ F22d Glowplugs dont work #12
So why not just spend $20 and get a copy of the F/FX 22 parts book if you're going to keep the tractor?
/ F22d Glowplugs dont work #13
Why not compare it to your tractor and see if it's the same?
/ F22d Glowplugs dont work #14
That is a nice qlty schmatic, what publication is it from? It sure looks nicer than the ones in the manual I have from Murray.
I got the schematic off of this site, I havent had time to go out and take apart the dash to test the circuit according to the schematic as I work graveyard. I will when I get a chance. Thanks for the help guys, I will keep you posted.
2010 GMC SIERRA 1500 (A67714)
2010 GMC SIERRA...
2015 Yamaha 350hp 4-Stroke Outboard Boat Motor (A66738)
2015 Yamaha 350hp...
2016 JOHN DEERE 5075M TRACTOR AND BUSH HOG (A66091)
2016 JOHN DEERE...
2000 CATERPILLAR 322BL EXCAVATOR (A65053)
2000 CATERPILLAR...
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
2016 FREIGHTLINER CORONADO 122 SD (A67714)
2016 FREIGHTLINER...
