F150 Front 2" receiver hitch build (8" offcenter for V8 )
   / F150 Front 2" receiver hitch build (8" offcenter for V8 ) #21
Nice job Sodo. What does anyone think about using this for a front winch?
   / F150 Front 2" receiver hitch build (8" offcenter for V8 ) #22
Re : "Crows and Steve"
Give him time. Prolly not UP yet. :D
BEAUTY.
Terry
   / F150 Front 2" receiver hitch build (8" offcenter for V8 ) #24
"Give him time. Prolly not UP yet" - Was too - I'll have you know I was up at the crack of 8:32 this morning :laughing:
Jeez, Sodo, ya give a guy a solution to not one, but TWO problems and he STILL makes fun of ya... (how soon we forget whose ideas we steal :D ) - Oh well, you keep on tiggin' HF junk together and I'll keep on usin' REAL receiver tube - twice as thick an' less than HALF the cost per foot (can't help retaliation after all the "shiny" digs - but at least I never have inclusions in my welds) Downside is I gotta find OTHER excuses when I make "less than stellar" welds :(
I do like you're "sneaky hitch pin" though...
Whatswrong - "only thing I could think of was launching a boat and wasn't to sure that would work well" - from experience, it WON'T if ramp is very steep/wet and your pickup is 2-wheel (rear) drive - since most of the weight will be on the front wheels. But 4x4 works GREAT.
First one of these I built in 1976 was on a '73 F250 4x4, and I regularly did "impossible" things with it. Did mine with two receivers, each lined up with one of the frame rails - that way I could move the hitch from one side to the other depending on conditons and which side I needed to see better... Steve
Weld is stellar, for having powdercoat inside :punch: the joint..... But how did you notice that with all the "shine"?
   / F150 Front 2" receiver hitch build (8" offcenter for V8 ) #26
I wear SHINE glasses (other people call 'em SUNglasses :rolleyes:) 'sides, it all looks the same thru a welding hood :D
I've since beefed it up.
The whole receiver was bolted onto the front side of the F150 frame flange.
I made it mainly to move empty trailers and hold stuff like a lumber rack.
Then wouldn't you know it I had to maneuver a heavy one.
I knew that day was coming and it came.
Had to horse a 5,000 lb boom lift around and it was visibly flexing.
I had to push the boom lift over very uneven ground over tree-roots etc, in granny & 4wd & locked up!
I kinda knew it needed an a brace on the backside for any weight on the receiver, but didn't wanna build it at the time.
Nows the time.
678229d1606693877-f150-front-2-receiver-hitch-brace_5313done-jpg
Here's the back-side brace, looking down, from behind the grille.
To the right -----> is forward.
That's 1.5" square tubing with .25 thick walls.
Those tabs are all 3/8" thick.
This basically braces the inside of the front frame flange.
The hitch is bolted to the outside (front) of this frame flange.
678228d1606693877-f150-front-2-receiver-hitch-brace_5310-jpg
I attached it to the truck frame with this 3/4" all-thread rod.
There was a hole thru the frame box section with appx. 7/8" holes
Note the "shoulder-nuts" that I made with the angle grinder.
These engage existing Ford holes in the F-150 frame.
It's firkin' solid now!
But..... I have never had to push any real weight around since.
   / F150 Front 2" receiver hitch build (8" offcenter for V8 ) #29
There wasn't anyplace to hook on to my 1997 Dodge 2500 4x4 diesel if I got stuck. I went to a shop somewhere in the Detroit area and told them I wanted hooks installed. They said for some more money,
don't remember how much, they said they will install a receiver hitch and hooks at each end.
Never used it, but I liked having it in case I got stuck or needed to back a trailer into a tight spot. I still have the truck.
People see the receiver hitch on the front and ask me if it's hard to go down the highway that way with a trailer. I tell them it's not too bad once you get used to it.
   / F150 Front 2" receiver hitch build (8" offcenter for V8 ) #30
I can push this one pretty fast on the driveway and through the pasture:
Pushing two, I have to slow down a little bit and concentrate more:
It is muchly easier to pull them:
2019 Harley Davidson Electraglide (A55973)
2019 Harley...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
183 (A52705)
183 (A52705)
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2017 Ford F-350 Crew Cab Pickup Truck (A55973)
2017 Ford F-350...
