Tire Selection F150 4x4 tire question
   / F150 4x4 tire question #11
Honestly I would put it on and wouldn't bat an eye, it's a non issue.
   / F150 4x4 tire question #12
They are eight years old. You should be re-replacing them at this point anyway.
I have tires older than that on road vehicles that I trust. No sun damage, kept in a Garage.
On tractors I sure hope there is no eight year rule. :D
   / F150 4x4 tire question #14
Put it on a rear and brake torque it and burn the tire with deeper tread down to what the others have... dilemma solved.
   / F150 4x4 tire question #16
Absolutely not an issue. This is done all the time. Probably millions of vehicles on the road with two rear tires with unequal tread or inflation.
   / F150 4x4 tire question #17
I really don't believe you could tell at all and I don't think it would have any ill effects. People drive trucks all the time with a tire that is more worn than all the others because of the single drive rear wheel, If it was a different size that would be a different story, I would run it on the rear if it was me.
Single drive rear wheel? Both rear wheels drive, unless one is on ice; a differential sends equal torque to both wheels.
   / F150 4x4 tire question #18
A limited slip differential would be more sensitive to different tire sizes than a standard differential I would think. The clutches try to keep both sides going the same speed. It seems like it would wear the clutches if they're different. I don't know which you have.
I found a good deal today on 5 new BF Goodrich AT tires in 265/70/R17. A few days ago, I found a great deal on an aluminum alloy rim that matches my truck. It had a good TPMS sensor in it too. All set now to begin 5 tire rotations when needed. Selling the old spare steel rim and tire.
I never liked the Hankook A/S OEM tires. They slipped around on gravel and looked kind of "cheap". I almost didn't buy the truck back in '10 because of them.
Thanks for your input.
   / F150 4x4 tire question #20
Agree! Don't throw good money after bad by buying a new tire to go with the old. Put it on front and wear the other three out, then get a full set of what you want.
prs
2021 Ditch Witch SK800 Mini Skid Steer Loader (A57453)
2021 Ditch Witch...
(INOPERABLE) DYNAPAC 772 DOUBLE DRUM ROLLER (A58216)
(INOPERABLE)...
2000 INTERNATIONAL 4900 CAR HAULER (A59575)
2000 INTERNATIONAL...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
2016 INTERNATIONAL WORKSTAR 7600 (A58214)
2016 INTERNATIONAL...
1980 Gleaner F2 with heads (A56436)
1980 Gleaner F2...
