Spreader Ezee-Fow Spreader settings/chart
   / Ezee-Fow Spreader settings/chart #1
Rathpr
I recently purchased an Ezee-Flow 12-ft drop spreader. The chart with the opening sizes is attached to the spereader and I have included a photo. The chart refers to red numbers and black letters but the markings on the spreader are missing. Does anybody have a photo or documentation as to what the marking mean and where they would be located. Thanks!
   / Ezee-Fow Spreader settings/chart #2
On the one I use, there is a cam shaped piece on the front frame that is used to stop the handle, and the numbers/letters are on the cam.
There is a single bolt that holds it, and you loosen the bolt, rotate the cam to obtain the proper setting, then tighten it back down
Thanks for the info. I took a look and all the lettering and numbering on the cam is gone. Is there anywhere that describes what the it used to look like? Thanks.
   / Ezee-Fow Spreader settings/chart #4
I'll try to see if I can get a picture of it tomorrow.
   / Ezee-Fow Spreader settings/chart #5
This may help?
   / Ezee-Fow Spreader settings/chart #6
The cam on mine is totally different, so it may not match up with your chart:
There is a 1/4 inch spacing between the marks, and the cam is about 6 inches at the longest dimension
These pics show it set on #6
Thanks for the photo. I appreciate evryone taking the time to post these. Unfortunately mine doesn't have any markings. i think they were painted on. I think I can take these and find some equivalent.
   / Ezee-Fow Spreader settings/chart #8
I just bought one to resell. I will check it out tomorrow. Ken Sweet
   / Ezee-Fow Spreader settings/chart #9
It wouldnt be hard to mark the one you have now, and stamp some numbers on it.
I've been using mine for about 8 years now, and have repeatedly used the same settings 90% of the time.
The chart seems like a good thing, but truth is it won't really be that accurate.
With a little experience, you'll soon figure out how much you need to open it to do what you want with different materials
   / Ezee-Fow Spreader settings/chart #10
I agree about the settings. For lime I just open mine up all the way.....and I believe I put down about 1 ton per acre with a single pass. For seeds and fertilizer I think your going to have to experiment a little to determine the rates dropped.
1986 ASPT 30ft S/A Pole Trailer (A49346)
1986 ASPT 30ft S/A...
2014 Gillig Transport Bus (A50323)
2014 Gillig...
MCELROY COOL PACK 20 (A50854)
MCELROY COOL PACK...
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
1999 FREIGHTLINER FL80 (A50854)
1999 FREIGHTLINER...
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
