Oil & Fuel EZ Way to Refuel?
   / EZ Way to Refuel?
Ahh come on - There is hardly any difference between water and diesel.:laughing:
   / EZ Way to Refuel? #22
I use a 5 gallon diesel can and a tube to siphon it. That way I just set the can on the hood, stick in a tube, one quick suck to prime and it drains most of the can. Lot's of peeps don't like to start a siphon, but I learned young and haven't gotten a taste of gas or diesel in decades.
Having written that I expect a mouthful next time.
   / EZ Way to Refuel? #23
I had a good smart allic idea right up until I read "cheapest".:laughing:
The best idea I've seen yet consisted of a small fuel tank on a stand and a pump. I'm toying with the idea of building a small portable refueling station (25-50 gallons) which can be put into the back of the pickup to take to the station and refill. The rest of the time it would have a home in the shop where it can refuel the tractor easily. Not sure yet whether to use a 12 volt or 110 volt pump. Both have advantages and disadvantages.
This is a 12 volt pump powered from a 110 volt outlet but can be powered by car truck or tractor .
This set up combines the best of both worlds.
   / EZ Way to Refuel? #24
Solution? Most people can't get 50 gallon drum to the station and back, weight about 400lbs ,when filled?
   / EZ Way to Refuel? #26
Yes but i dont have any pics of the cans on there. I will post a few picks of it. :thumbsup:
Heres a pic of the cans. Like i said i like them alot.
   / EZ Way to Refuel? #27
First system I built
Solution?
Most people can't get A 50 gallon drum to the station and back, weighs about 400lbs ,when filled?
My present set up I built.
Not a problem with either of these systems because there is no llifting moving or handling of a drum of fuel .
   / EZ Way to Refuel?
Anybody come across a nice handpump? - Seems like it couldn't need turned too much for 8 or 10 gallons and would take a lot of the complexity out of the system.
   / EZ Way to Refuel? #29
Some manual bilge pumps, like the Bosworth 400H (about $50 from Hamilton Marine) are impervious to most fuels, including diesel. The company does not encourage their use for fuel transfer, of course, but that's what guys do. The base mounts to a board, so a fixed station would be the ticket. I'd probably cut a hole in the can cap to stabilize that section of hose but I don't use the machine enough to justify the toy. (Hmmm.)
Here's one. There are other models.
PUMP GUZZLER 400 10 GPM 1 ID 104857
   / EZ Way to Refuel? #30
Gravity flow ... the 300 gallon tank on a stand (higher than the tractor) and the local fuel company delivers ....
2012 PJFS25 Goose Neck Trailer (A55973)
2012 PJFS25 Goose...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
Deere 333G (A53317)
Deere 333G (A53317)
Cushman Electric Cart (A55853)
Cushman Electric...
2019 Haulotte Star 20 ACE 19ft Scissor Lift (A55973)
2019 Haulotte Star...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
