Extremely slow hydraulics
/ Extremely slow hydraulics #1
scouse lee
On a farm in Devon U.K.
Ford 3000
Hi, I have a 1970 Ford 3000 that I use to run a log splitter. I have had the tractor for about 18 months & the hydraulics have been working ok up to now but the other day I tried to use the splitter and 1st of all noticed that the arms were having trouble lifting, in fact they wouldn't move at all for about 5 minutes, then when I tried the splitter it is going so slow that it is not worth using at all. The tractor hasn't been used for about 3 months as it has been in storage while we moved house, the splitter is about a year old & I know that is working ok. I'm hoping it is not the pump & intend to look at the filters 1st, can anyone tell me how to remove them please.
Cheers Guys:thumbsup:
/ Extremely slow hydraulics #2
Have you checked the 3PH speed controller knob typically located below and in front of the seat. Then I would check the filter and/or strainer for restriction.
is this the handle that either sends the oil to the arms/the arms & other apparatus/other apparatus alone, if so I believe when it's fully pulled out it should send the oil to my splitter but I've always had to have it in the middle position.
/ Extremely slow hydraulics #4
There's a suction screen inside/under the reservoir that needs to be removed and cleaned......best to do this and change/clean reservoir hyd oil while you're at it.....these screens will starve the pump potentially ruin it.....:thumbsup:
/ Extremely slow hydraulics #6
IIRC it comes out under the reservoir after taking the suction hose off...maybe someone here has a parts breakdown....
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2003 Ford Winstar (A64557)
2003 Ford Winstar...
2014 Kia Sorento SUV (A64557)
2014 Kia Sorento...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
2022 CATERPILLAR 259D3 SKID STEER (A65053)
2022 CATERPILLAR...
