Extracted oil from bush hog gear box
   / Extracted oil from bush hog gear box #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
It's 8 years old; so, I extracted the oil from the Frontier RC2048 cutter gear box and replaced it with new GL5 stuff. There was some water initially at the bottom.
I'd read posts on here before about folks saying they had milky bush hog oil.
Guess it does not get hot enough to expel the tiny bit of oil that gets absorbed in it from gear box breathing hot/cold. The old LX4 would get pretty warm.
   / Extracted oil from bush hog gear box #2
How did you "extract" the oil? If there is water in the lower bearing/seal area, only way to get it out is flip it on it's side.
I used an oil extractor with hand pump vacuum. The sucking part sticks down in one corner. First thing it picks up is any water, which would be on the bottom.
The fluid looked great once it sucked that little bit of water and stuff in between. Not much of it.
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2015 Honda Accord Sedan (A56859)
2015 Honda Accord...
Case Skid Steer Backhoe Attachment, S/N 391998, 20" General Purpose Bucket, Asset# 71 (A59076)
Case Skid Steer...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Hose Reel (A55758)
Hose Reel (A55758)
LOT: (50) 14 Oz. Tubes of Star Fire Multi-Purpose EP 2 Grease (A59076)
LOT: (50) 14 Oz...
