Extracted oil from bush hog gear box
   / Extracted oil from bush hog gear box #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
It's 8 years old; so, I extracted the oil from the Frontier RC2048 cutter gear box and replaced it with new GL5 stuff. There was some water initially at the bottom.
I'd read posts on here before about folks saying they had milky bush hog oil.
Guess it does not get hot enough to expel the tiny bit of oil that gets absorbed in it from gear box breathing hot/cold. The old LX4 would get pretty warm.
   / Extracted oil from bush hog gear box #2
How did you "extract" the oil? If there is water in the lower bearing/seal area, only way to get it out is flip it on it's side.
I used an oil extractor with hand pump vacuum. The sucking part sticks down in one corner. First thing it picks up is any water, which would be on the bottom.
The fluid looked great once it sucked that little bit of water and stuff in between. Not much of it.
2014 Ag Spray Schaben Sidedresser (A56435)
2014 Ag Spray...
16 BLADE DISC HARROW (A52708)
16 BLADE DISC...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 DRAGON ESP...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
New/Unused CFG Industrial QK20R Mini Excavator (A57453)
New/Unused CFG...
