Extra weight on a scrape blade
/ Extra weight on a scrape blade #1
lancem
Martin,Ga
YM2000
When I use a scrape blade with my ym2000 it just bounces along on top of the dirt. I am thinking about adding a bracket on to the blade so I can hang a few suitcase weights on it. Any thoughts?
/ Extra weight on a scrape blade #2
Sounds like a Typ. Scrape blade Prob. If so your be hanging weights on it. The 3pt. only has pressure up not down. My BB will do the same on my gravel Dr. until I loosen it up and the weight of the Gravel will hold it down. Thats were I'll even drop the forks to make it squicker. ;)
/ Extra weight on a scrape blade #3
More weight will make the blade work a lot better. My old scraper blade even has a four hole bracket on the back for mounting weights or a weight box. I don't use it much so I haven't bothered.
/ Extra weight on a scrape blade #4
Here is what I added to mine. I made the weights to hang on the front of my tractor but later bought a couple of suitcase weights so these got moved to my blade. They weigh about 50 lbs each. 200 lbs on there definitely makes a difference.
/ Extra weight on a scrape blade #5
I took a similiar approach with suit case weights so I could use them on my back blade and to add more weight to a box blade. I drilled and tapped the weights which allows it to slip on both attachments and lock them in place.
Thanks for the ideas. I will post some pictures after I am done.
/ Extra weight on a scrape blade #7
You could also get a rod and wed it on and hang old workout barbell weights, there usually cheap at thrift stores.
/ Extra weight on a scrape blade #8
I put 350lbs on my box blade and that made it a useable attachment. Before it was a skipper not a ripper unless it was almost muddy. I need to hold it back now or it will cut more than I want sometimes.
/ Extra weight on a scrape blade #9
On the land plane that I built, I built a rack on top to hold 6 cement blocks, just under the max lift on my 186D. Works great.
/ Extra weight on a scrape blade #10
Did you try adjusting the toplink?
/ Extra weight on a scrape blade #11
I wasn't going to chime in on this one being I never have used a " scrape blade " But I would say unless the scrape the OP is using is a el-cheap-o scrape, he should be able to achieve better ground engagement through adjusting the top link in order to get the correct pitch to the blade,
even though I personally have not used a scrape-blade (not really had any call for one), Though many years ago when tractors were used in landscaping business I watched them around the new homes when prepping the finish grade, I've seen where they swing the blade 180* in order to float/drag the top soil, I don't think I recall seeing anyone actually use a scrape blade to do any serious digging, But I guess with enough weight it would dig,
My neighbor had a tractor with a scrape blade, about once each year he would scrape his 500 ft driveway, I think it was just to fill in the pot-holes and drag the gravel from the edge back into the driveway where it is most needed, I drag our driveway with my FEL pulling backward, It seems to me that the blade being backward works pretty well, instead of having the blade dig in, Just my:2cents:
/ Extra weight on a scrape blade #12
Be very careful about adding weight to your back blade/scraper as you can bend your A-frame supports to the top link, making it impossible to raise or lower your blade.
Better to lengthen the top link to increase the angle the blade digs in at; or angle the blade to get more of a cutting action instead of just a scraping one.
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
2007 JLG 660SJ SKYPOWER TELESCOPIC BOOM LIFT (A65056)
2007 JLG 660SJ...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
DIAMOND TOOLBOX (A68842)
DIAMOND TOOLBOX...
2015 Ram 1500 Pickup Truck (A64556)
2015 Ram 1500...
2012 Freightliner M2 106 Terex Hi-Ranger TL41 41ft. Insulated Bucket Truck (A66736)
2012 Freightliner...
