Extension cord for block heaters?
   / Extension cord for block heaters? #1
Lisbon Maine
John Deere 4200
I want to replace my extremely stiff extension cord that I connect to my JD 4200 hydro unit block heater. I need at least thirty feet so I guess that means I will need to purchase a fifty foot cord. My thinking is a 12 gauge wire should do it unless you folks tell me different. We are having a winter where mornings are below 0 degrees Fahrenheit a few times a week. So I want a cord that will remain flexible enough so I will be able to coil it up loosely when not in use. Does this mean I will need to get a rubber covered cord or are some vinyl cords available that will remain flexible at or below zero?
Thank you for your time and knowledge.
   / Extension cord for block heaters? #2
I've never read any specifications for cord requirements. I've used 14 gauge cords. Never noticed any problems. I normally use a 12 gauge if the tractors are parked in the machine shed just because that's where that cord is.
Got my curiosity up now. I'll do some research in regards to manufacturer's specs for cord size and amp draw.
   / Extension cord for block heaters? #3
   / Extension cord for block heaters? #4
I believe some extension cords are rated for cold weather use but no clue what the cover material is.
i believe 14 gauge is rated for 15 amps and 12 gauge for 20 amps
   / Extension cord for block heaters? #5
Look for a cord that specifies something about cold weather. It will have a jacket that's more rubber like and not vinyl. The block heaters that I've had over the years were never over about 1800 watts, I think that was on my older Fords with the 7.3.
A smaller tractor might be 1000-1200 watts and a 14ga extension cord will easily handle 2400 watts.
The moral of the story is spend you money on the jacket of the cord, not un necessary expensive copper. šŸ‘
It's been several years and the last good cords I bought were blue in color and the jacket was easily distinguished by feel NOT to be the cheap, hard vinyl covering.
   / Extension cord for block heaters? #6
Up here in the far north, we have cold weather flexable extension cords available.. They are not cheap but well worth the money..
On my tractor I assembled a 1 meter long extension cord from an old frayed flexable cord.. It is securely fastened to the loader frame and goes between the cord on the block heater and the cord in the wall outlet... When the heater is plugged in I always wrap the cord around the steering wheel...
This may seem a lot of trouble.... However....
You DO NOT want to see how it turns out when you go 11 meters out of the shed when using a 10 meter cord....
Take my word on that....
   / Extension cord for block heaters? #7
14 gauge is fine. I work in new products for a company that makes plugs so it's usually easier to make my own extension cords. I just checked the garage cord I usually use for block heating tractor and/or Ford truck. I have a really long version that is 14AWG SJOOW portable cord. It stays flexible and easy to manage in temps below 0. The OO means oil resistant which is good for garage and the W is for water & weather rated. SJEOOW cord has a more flexible insulation (Elastomeric) around the individual wire conductors and is supposedly even more flexible at low temps. I got my SJOOW at big box store by the foot.. Pricey time to buy anything made with copper wire so 14 gauge will save you $. Your heater is probably only about 400W so no issue with 14 gauge and draw. They sell cold weather extension cords, but a 14 gauge version 50' long could cost more than the DIY route. Good luck
   / Extension cord for block heaters? #9
Never plugged either of mine in and it gets real cold here. I don'
t have power in the big hay barn. They always start however. I just maintain the electrical system and run good batteries.
   / Extension cord for block heaters? #10
I do the same subtle reminder myself. šŸ˜†
Bucket of Welding Rods (A57454)
Bucket of Welding...
Toro Super Blower Vac (A57453)
Toro Super Blower...
2008 Bobcat S250 Compact Wheel Loader Skid Steer (A59228)
2008 Bobcat S250...
2006 Ford F-350 Pickup Truck, VIN # 1FTWX31P16EB57079 (A57453)
2006 Ford F-350...
2012 Freightliner Cascadia (A56436)
2012 Freightliner...
2007 Sterling Acterra Service Truck, VIN # 2FZACFDC67AY51272 (A57453)
2007 Sterling...
