Engine Block Heater: OK to leave plugged in?
   / Engine Block Heater: OK to leave plugged in? #11
Is there any truth to diesels becoming "dependent" on block heaters to start? I have had a couple diesel mechanics tell me with certain trucks they have seen that have regularly been plugged in that in any cold weather they will not start without being plugged in. Also, I assume it is better for the engine to be plugged in very cold weather to warm and help with initial lubricant circulation, but does one really need to do so if the tractor or truck or whatever equipment starts? JDG lives where it can get quite cold, but I know we had a minus two night here last week and my 3720 started up without any trouble. I usually park inside but had it out that night. Am I doing wrong by not running a block heater myself?
John M
   / Engine Block Heater: OK to leave plugged in? #12
Start up is the most stressful time for the engine so extreme cold start up is even harder on it, having a prewarmed block helps to lessen the stress, I use my heater at temps lower than 20 degrees and you definitely should when the temps get down to zero, your engine will thank you.
With the truck it's more of a necessity, with 6 cylinders it would take forever to warm up with out the block heater, takes 10 to 15 minutes to get cab heat when not plugged in, as opposed to 5 minutes with it plugged in.
   / Engine Block Heater: OK to leave plugged in? #13
?????? What would be the difference between the anti freeze heating up under operation or with a block heater? If the trucks are starting hard it would be from another problem not a block heater.
   / Engine Block Heater: OK to leave plugged in? #14
Just some info for figuring your electric usage if you leave it on all the time. Most block heaters are between 400 and 600 watts for small diesels. Just replaced mine because water got under the power cord plug at the heater end and electrolysed the brass heater contact pin to dust. Should have known when it kept tripping the GFI. $35 got me a new heater and power cord. Old unit was 400 watts and new unit was 400 watts. Google ZeroStart for block heater info. Most don't know the power cord also plugs into the heater with a very small half moon connector. Put some RTV or grease on the heater pins to keep them dry.
   / Engine Block Heater: OK to leave plugged in? #15
Like shaley says, most block heaters are aabout 400-600 watts. I don't think a commercial duty timer is necessary unless your using some of the higher inline heaters which are up to 1500 watts which is still just over 12 amps.
   / Engine Block Heater: OK to leave plugged in? #16
I found this past weekend in near o degree temps I only need about 2hrs to sufficiently warm the block. When I turned the key to run the temp gauge on my 5400 was in the green same as an all night cook.
   / Engine Block Heater: OK to leave plugged in? #17
John M
Nope. It's an inanimate object. It can't be trained to do anything.
   / Engine Block Heater: OK to leave plugged in? #18
But....I talk to my tractor, and sometimes it talks back!!!
John M
   / Engine Block Heater: OK to leave plugged in? #19
John, you are over medicating yourself. Please let your wife give you your daily meds from now on.
Bunker Rake (A59228)
207277 (A52708)
207277 (A52708)
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A56436)
2023 Kubota Z412KW...
2023 Chevrolet Tahoe SUV (A56859)
2023 Chevrolet...
2014 Chevrolet Silverado 1500 (A60460)
2014 Chevrolet...
Adams Tender / Magnolia Trailer (A56436)
Adams Tender /...
