Extending Draft Links
/ Extending Draft Links #1
tessiers
Platinum Member
Central Maine
05' JD 790 - 53' Ford NAA - 70' Massey Fergusen 135 diesel - 67' John Deere 3020 deisel - 77' John Deere 2130 - 1950 John Deere MC
I am looking for a set of extending draft links for my JD 790
My Father (59) Has an extremely hard time changing implements
I have tried two "quick attatchment" systems, and have not had any luck. They are good for one or two implements but need constant adjustment for multiple attatchments.
We Have both worked on dairy farms that have extending draft links on bigger tractors but nothing this size.
My Dealer says nothing is available for my tractor. I did some footwork and a set of Kubota links from a L3140 are the right length and pin diameters but the sway chains are inside instead of outside.
Has anyone been though this or found a solution?
/ Extending Draft Links #2
Perhaps those from another series JD tractor would fit the 790. I know the bigger JD CUTs can be had w/ flex links.
/ Extending Draft Links #3
Take a look at the links on the JD 3x20 series. The tractors are about the right size and the sway bars are on the outside.
I have them on my 3520 and they work very well.
Thank You For The Tip
I only saw them on bigger tractors at the dealer but I thought they must be available. Will Check the 3020 series
/ Extending Draft Links #5
I assume you tried Pat's system.... am surprised if it didn't work for you... it's worked for all sorts of implements for me...
I Have it hanging on a wall in my barn. It Was allright but required adjustment for each attatchment.
/ Extending Draft Links #7
My Kioti DK40se has telescoping links and I imagine they might fit a JD too. Not sure of the replacement price.
/ Extending Draft Links #8
tessiers,
Are you sure you tried Pat's Easy Change. They are two pieces that go on the ends of your lift arms only. You shouldn't have to adjust anything. just back the hooks under the attachment pins and lift. If you are not completly aligned with the attachment, just use the bumber on the hitch to move your attachment and let the tractor do the work. The lift arms still move in and out to what ever width your attachment is. I was just wondering because you say you have "it" hanging on your wall makes it sound like the frame system, not Pat's.
Thanks
Pat of Pat's Easy Change
/ Extending Draft Links #9
Your use of the word " it " suggests that you might be confusing Pat's Easy Change (PEC) with the cumbersome one piece Quick Hitch (QH) sold by SpeeCo, Harbor Freight, and a few others. JDs iMatch is designed on a somewhat similar concept
The PEC system consists of a pair of pickups, one for each lower lift arm. I think the JD790 is Cat 1, so by design the PEC will extend your lift arms about 3.5 inches. After initial installation, no subsequent adjustments should be required.
//greg//
/ Extending Draft Links #10
I heartily endorse Pat's easy change. Works great on NH TC40 DA.
/ Extending Draft Links #11
My bad... I should have initially posted the link to Pats Easy Change System to avoid confusion.... here is the link.... please check it out, tessiers. I'd be interested to know, for sure, if you actually used that system, or something else. As others have said... no adjustments are required across many, many kinds of implements.
I Have Tried The Pats System. It has a bar that adjusts the width between the ball ends. My snow blower is a little wider and my wood splitter is narrower, ect ect. I have also tried the EZ Hitch (Frame) which simply would not work on the snow blower. Luckily i was able to get a refund for that. The Koti Arms Look surprisingly like mine I will try that
/ Extending Draft Links #13
I like extendable draft links for the superior mechanical soundness of the system, but I couldnt call them easier to use than Pats. The only problems I experience with Pats is due to the attachment paraphernalia hanging out and snagging, the loss of the outer ball swivel action, and the increase in draft arm length. None of these make them harder to use than extendable links - only less mechanically suitable. The system is quite well done however. In the vast majority of use situations the PEC convenience wins out.
larry
/ Extending Draft Links #14
You need to break out the owner's manual and learn how to use your three point hitch. Distance between the lift arms is controlled by lengthening or shortening the side stabilizer links.
The "bar" that you can order with the PEC is only used to initially spread the lower lift arms as you're hooking onto the implement. Once the implement is connected to the PEC, you take the spreader bar off.
//greg//
Exactly Constant Adjustments with each piece of equipment. I worked on a farm most of my life and I am pretty familiar with hooking up equipment
2013 TYTAL CRUDE TRAILER (A67714)
2013 TYTAL CRUDE...
Unused 2022 Hustler Lift Max LE110 SS Bale Forks and Frame Tractor Loader Attachment (A66734)
Unused 2022...
2019 FORD F-350 SUPER DUTY (A67714)
2019 FORD F-350...
Unused 2023 Monroe-Tufline DS1120T 10ft. Hydraulic Box Scraper Tractor Attachment (A66734)
Unused 2023...
STAGECOACH  16 FOOT FLATBED TRAILER (A67714)
STAGECOACH 16...
PALLET OF FUEL TANKS (A68842)
PALLET OF FUEL...
