Toplink Extending a hydraulic top link
   / Extending a hydraulic top link #1
tpulley
Wake Foest NC
Kioti DK45SE
I went to the local ASC office today and bought a cat 1 hydraulic top link, hoses and fittings.
I put all the pieces together and boy is this sweet. My only concern is I really want two or so inches of travel more from it. Other than going to their cat 2 that gives me the two inches any suggestions how I can get there.
Terry
   / Extending a hydraulic top link #2
If you don't weld yourself, take it to a welding shop and have them cut off the ball on the tractor side (cylinder end) and weld in a 2" or 3" piece of the same size metal to the cylinder end. Then weld the ball back onto that.
They may even weld in a heavier piece because it would take the side forces even better.
You must have a Pat's Easy Change. I did the same thing on another tractor before getting the "insert" style Pat's on the M7040.
That's a good idea. I do weld some, but I don't have anything to cut it with, well... maybe its soft enough to cut with a hack saw. I will poke around and look for some extra metal.
   / Extending a hydraulic top link #4
A hacksaw will work or maybe a Sawsall with a metal cutting blade. Be sure to grind an angle on the weld areas to get 100% penetration. Like this: >< Make several passes alternating on both sides to prevent warping.
You don't want it coming apart at an awkward moment.
Oh, and their Cat 2 hydraulic top link can be bushed to Cat 1 if you want to go that route. It is a little heavier duty, also.
   / Extending a hydraulic top link #6
Terry
Do you want it 2 or so inches longer, or 2 or so inches more travel? NOTHING that you do will get you ANY more travel. If you want more travel you need to get a different top link. ;)
   / Extending a hydraulic top link #7
MtnViewRanc is right. The extension is only moving the starting point. If the stroke is OK the extension will work. If you make a threaded extension, it could be variable.
It is more correct to say I need to move the starting point as opposed to changing the stroke. The first 3-4 inches or so are not being used right now.
Allen in TX has the exact idea I want to accomplish. I am now looking around for the rod/pipe to make the extension.
I am thinking my mig welder should work. What do you guys think?
   / Extending a hydraulic top link #9
so good luck for you! :)
   / Extending a hydraulic top link #10
It depends on how the shaft end is configured now.
>If it is a piece of thick flat bar then splice it with the same.
>If it is round, splice it with round as did Allen in TX.
>If you can get away with not cutting the ball flush to the cylinder it would be easier and stronger to splice in a matching piece with a 100% weld.
Personally, I would not use MIG. It will stick it together but penetration is limited with the heavier materials.
It will take a (open) root pass and several cover passes on both sides of the spliced shaft. This is best done with stick.
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
Advance SC750 28in Floor Scrubber (A53421)
Advance SC750 28in...
Adams 5 Ton HC Spreader (A55301)
Adams 5 Ton HC...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
