Extended my sprayer boom
/ Extended my sprayer boom #1
jdgreg
Warrenton, Va
I had a 15 gal spot sprayer from TSC, but wanted a boom for it. I got one from Cabella, that was very complete and good price. Here's the link to that thread: http://www.tractorbynet.com/forums/attachments/86733-atv-style-spray-boom.html?highlight=cabella
It came with a solid 4' boom that had a 7' spray pattern, but after using it once, I quickly realized I needed more. So thanks to many here, I borrowed a lot of good ideas and made an extension.
First thing I needed to do was to build something I could mount it onto the tractor with. I had already bolted 1" square tubing onto the bottom of the tank, and welded slightly larger tubing onto the inside top of the FROPS of my lawn tractor. With the FROPS folded down, this allowed a very stable way to carry the sprayer on my lawn tractor to spray around tight areas.
So I took this idea and built on it. The first pic, I got a regular draw bar from TSC, used the ball to secure a piece of U channel, and welded a 1" square tube to it, and made a bracket for the top link. This way I have a functional draw bar if I need to move a trailer around, as well as good base for the sprayer. Oh yeah, and I had to paint it the right color. ;)
The second pic is of the sprayer connected to the draw bar (I use a tie down trap to secure the sprayer). The wire has an inline switch, so I can better control when to cut off the sprayer. I have a connection inside the cab that is used for either the sprayer or a small heater for winter.
The third pic is with the boom extended out, total length from nozzel to nozzel is 108", which should give me about an 11' spray pattern.
The fourth pic is the actual spray pattern.
All in all, it looks like it will work very well, tank may be a little small, but that should be ok for now.
Again, thanks for the ideas from PineRide, and many others. :D
/ Extended my sprayer boom #2
That looks like a nice setup. You will probably want to get a larger tank someday, though. That way you won't have to stop and refill as often.
I had a 15 gallon trailer sprayer that covered 80". It worked well but the biggest problem I had was trying to keep the spacing right so I did not overlap the sprayed area or leave gaps. I now have a Kubota B3030 with a 60" MMM. I wanted something that I could spray with that would allow me to use the mower tracks as a guide. 5' would have been too small and 15' would be too big to get around the yard so I looked for a way to acheive a 10' spray pattern. I found a 25 gallon "ATV" sprayer at a local farm store and, as luck would have it, it had a folding boom with 3 spray nozzles that covered 120". I made my own mounting bracket that fits into the 2" receiver hitch I have on the tractor. It came with an inline switch that I wired into the tractor with a two wire connector so it can be easily taken on and off. By adjusting the height with the 3PTH I was able to acheive a perfect 10' spray pattern. I just skip every other pass that I made when mowing lawn and use the tracks as a guide. It has worked well to spray weed killer on the lawn and some roundup on an area I am converting from weeds to lawn.
/ Extended my sprayer boom #3
jdGreg are you trying to kill the asphalt? ;)
Loader Brackets (A65640)
Loader Brackets...
NEW Wolverine SP-15-84W Snow Blade (A62679)
NEW Wolverine...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
Cub Cadet MOWER (A64557)
Cub Cadet MOWER...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
2004 Chevrolet Tahoe 4x4 (MPV), VIN # 1GNEK13Z24R318274 (A61165)
2004 Chevrolet...
