Extendable lower arms
/ Extendable lower arms #1
Sweetwater, TN
RK55HC
New owner of a 55HC, my first tractor ever, so I appreciate reading these boards. When do you use the extendable lower arms? Are they for certain implements, or for ease of hooking up?
/ Extendable lower arms #2
Ease of hooking up. Common feature before quick hitches became popular.
/ Extendable lower arms #3
The tolerance between Lower Link "bullseyes" and Lower Link connecting pins is just a few thousands of an inch. The extendable Lower Links allows you to align implement and tractor for pin insertion without moving the tractor five times, nor jockeying heavy implements manually.
Lubricated, rust free pins insert more easily than beat up, dry pins. I like wax lube.
Telescoping Lower Links are a good feature.
/ Extendable lower arms #4
With the cab tractor (maybe open too) you get a rear operated lever to adjust the lift. Works w the extendable arms to make hookup relatively easy.
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
1960 IH Farmall Cub Tractor (A66285)
1960 IH Farmall...
2011 FORD F-150 (A65643)
2011 FORD F-150...
2022 EZ-GO ELITE...
2018 Freightliner M2 106 Elgin Broom Bear Street Sweeper Truck (A64556)
2018 Freightliner...
John Deere 12ft pull-type cultimulcher, Orion, IL (A65640)
John Deere 12ft...
