Extendable 3PH Arms
   / Extendable 3PH Arms #1
SLOBuds
Los Angeles/Central Coast, California
Kubota L35
I want to offset one side of my BB to do some grading work. Angle the BB so that dirt flows to one side when I drag.
Is there such thing as an arm extender that I can add to my current arm? It looks to me like some of the manufacturers provide adjustable arms. My arms are fixed length. And I can't seem to find any aftermarket product that does that.
So 2 questions:
  • Is it OK to drag that BB at an angle, and
  • If OK, how should I get by BB to pull at that angle - an arm extension? Something else?
Thanks
   / Extendable 3PH Arms #2
FWIW, my big NH has flexible link ends that extend out, but the manual says not to operate in the extended position (just for simplifying hook-ups). I don't see why you couldn't pull the box blade at an angle so long as it is strong enough, i.e., don't try with a lightweight, cheaply built unit.
   / Extendable 3PH Arms #3
I myself would not pull a BB on an angle unless it was designed for that purpose. The standard BB's frame is designed for straight on force.
David
   / Extendable 3PH Arms #4
I think you would just fill one side of the box. I need new extend able arms because my turn buckles are bent and the treads are stripping out. This also from pushing with the box blade
   / Extendable 3PH Arms #6
SLOBuds said:
OK OK ... so I'll rent a blade.
Thanks for keeping me from doing something stupid.
Gee. you had....you could have posted over on the Blond moment thread...:D
IRGC40 High-End Mini Golf Cart (A57149)
IRGC40 High-End...
2012 HEIL (A58214)
2012 HEIL (A58214)
2017 Mitsubishi Outlander AWD SUV (A56859)
2017 Mitsubishi...
2- 5TH WHEEL PLATES (A58216)
2- 5TH WHEEL...
2016 BOBCAT T550 SKID STEER (A52709)
2016 BOBCAT T550...
Caterpillar 48in Forks and Frame Loader Attachment (A56857)
Caterpillar 48in...
