experiences with my tiltmeter
   / experiences with my tiltmeter #1
PaulB
New York state
Kubota B1700 HST
I've had my tiltmeter for about 2 weeks now, and thought I would pass along some thoughts, as I believe this little piece of plastic may very well be the most important piece of equipment I have yet purchased for my tractor. I bought online from R&B manufacturing, the first time I ever bought ANYTHING online. (It is so easy it is scary, so I let my wife take the credit card!!) I bought the model 23c, because it is smaller than most of the others, and so fits on my dash better. I have a B1700, and the larger models, like the one Bird and Mark bought, would cover up most of my dash. The 23c just covers up my blinker idiot lights and partially obscures the other idiot lights, but not so much that I can't see them. I used the double sided sticky tape provided to mount the meter, as I couldn't find a good place to put the included bracket. The instrument itself has a real quality feel to it, kind of like a Snap-on tool compared to a taiwan one, and seems worth the price when compared to the $10 air bubble in a tube types I have seen at RV shops. I have found a few surprises since mounting the meter. For the most part, I found that my seat-of-the-pants feeling was pretty good - I found that , by comparing what I felt to what the meter tells me is the actulal slope, I start to feel like I am on a real slope at what the meter now tells me is around 12 degrees, get REALLY focused at 15, and give up on what I am attempting at around 18 degrees. That being said, there are some exceptions. I found that sudden changes in angle, like if one rear wheel rides up over a rock, fell a hell of a lot worse than the meter says they should, whereas gradual slopes feel less intimidating even though the angle may be greater. If I go suddenly from flat to 10 degrees I swear I'm going over, but if I gradually go across an increasing slope I feel confident up to 15 degrees or so. I have arbirarily set my personal limit at 15 degrees - If I can not do what I want to do without the meter staying under 15, I quit. It just isn't worth it to me to push the limits, then suddenly have one wheel sink into soft dirt and all of a sudden I go from 18 degrees to 25 (and then 90!) In this way I feel the meter will prove in the long run to be a great benefit to me, as I no longer have to guess. People who do this for a living might have to take chances, and proceed regardless of what the meter tells them, but I do this mostly for fun, so if the meter tells me to give up I can do so without any negative ramifications. I can NOT roll the tractor without severe negative ramifications however, and I think the tiltmeter will be most useful to me by acting as a policeman, letting me know when it just isn't worth it to keep trying to do whatever I am doing that has me at the far end of my comfort scale. I really think these should be standard equipment on all compact tractors, but until they are, by all means get one. Like I said I got mine from Randy at R$B, and am pleased with it. I can not for the life of me figure out why more small manufactureres, and maybe even big ones, don't spend more time and effort on this forum. I don't know how many tiltmeters R&B will sell because of their interaction on this board, but I know it is more than they would sell if they were NOT here, and also their presence here give we users easy access to information and products which are useful to many if not all of us.
   / experiences with my tiltmeter #2
URL for R&B
Paul,
I do a lot of mowing on hilly ground with my B2910. Using my old B7100 made me a little nervous, but on the B2910, I feel like I'm sitting WAY UP in the air and get really nervous as I traverse across the hill's face. What is the URL (internet address) of that R&B place you got your tiltmeter from. Also how much did it cost. I agree with you about manufacturers suppling them as standard equipment. I would also like to know if they publish any info about what angle the tractor can be tilted to sideways before you're courting disaster.
Don
new member
   / experiences with my tiltmeter #3
Re: URL for R&B
Don, it's interesting that you say you were more confident on the B7100 than on the B2910. I'm just the other way around. I don't like much tilt on either one, but I feel a little safer on the wider tractor. And if you want to shop the tiltmeters try http://www.tiltmeter.com
Bird
   / experiences with my tiltmeter #4
I just wanted to pass on my recent experiences after installing a tiltmeter from R&B Manufacturing on my B7100. I saw some discussion here on the board about these things a couple of weeks ago and also saw their ad on the home page. I checked out their website and thought, what the heck and I ordered one. I live on a pretty hilly 10 acres in Michigan and mostly mow, bush hog, and maintain a wood lot. I purchased on of the larger tiltmeters and mounted it on an angle-iron light bar I have installed on the front of the hood of the B7100. It's right out front and really visible.
This little device has REALLY changed how I mow and move the tractor around on my property. I installed it Friday night, mowed Saturday, and went WOW! I changed my mowing patterns almost immediately and expect I'll have to rearrange some trails through the hills in the woods to accomodate a much safer way through. I use wheel weights for added stability, have the rear wheels set wide, and have never really felt insecure on the tractor, but the little tiltmeter showed me right away that I was often times approaching an angle of risk. Simply put, it is an added safety feature when operating the tractor that I really don't know how I got along without.
I grew up on a dairy farm and have tremendous respect for power equipment and what it can do (both good and bad). I also believe in operator caution and safety, first and foremost. The tiltmeter ended up costing $38 delivered, and may be the wisest $38 I have spent in a long time.
I'd ask that everyone who uses a tractor regularly, compact or larger, click on the add R&B has on the home page here and at least give some consideration to the products they have to offer. Operator safety should NEVER be comprimised and these little gadgets can help all of us keep that in the front of our minds. Just my two or three cents worth.
   / experiences with my tiltmeter #5
Re: URL for R&B
Don here is a good link to alot of safty info for tractors and farm related equipment http://www.cdc.gov/niosh/nasd/menus/toptrac.html
I also bought a tiltmeter just a few weeks ago and I'm very happy with the service that I recieved from R&B very straight shooter and a quality product at a fair price. The only problem I had was deciding which model to buy he has quite a few models to choose from. But when I got on the phone with him he answered all my questions and let me take up at least twenty minutes of his time to help me decide on the best model for my tractor--very smart man. He knows who comes first and thats the customer. Now I would reccomend highly to deal with him after that transaction. I don't get a kickback even if the above sounds like I work there. I'm also in the service industry and can relate to a upcoming quality company!
Here is there address http://www.tiltmeter.com
   / experiences with my tiltmeter #6
Re: URL for R&B
Don't forget to mention 'code 57' for a $3.00 discount, only for TractorByNet.com visitors. /w3tcompact/icons/wink.gif
   / experiences with my tiltmeter #7
I think you would be very safe if you had a tiltmeter and stayed at 20 degrees or less. I just received two 25D tiltmeters, one for the front, and one for the side of the roof. I mounted both meters, then went out to check them out on my hillside. The meter showed over 25 degrees. So I turned around and came back in the same place, it showed over 25 degrees again. So I got a 4' level, and found I had a 17 inch drop in 4'.That comes to about 19 degrees. All I have to do now is figure what to do with two tiltmeters that are over 5 degrees out of kilter.
Bud
   / experiences with my tiltmeter #8
Bud has certainly raised an important issue. I've seen a big stampede to tiltmeters as safety devices on this board the past two months, yet this is the first I've read of anyone checking their accuracy. A safety device that works improperly is a contradiction in terms.
You other current owners would do us all a service if there is a way you can check the accuracy of yours. Maybe with the carpenters protractor level mentioned on the other tilt thread.
Glenn
   / experiences with my tiltmeter #9
What may have happened was, when they went from the 6 1/2" long meter to the 5" long meter, they used the same radius to form the tube for the indicator instead of a shorter radius. On a 25 degree meter that is over 20% off.
Bud
Bud - have you talked this over with Randy at R&B? We would all certainly like to know what he thinks of this apparent discrepency, and how to explain it.
2015 CATERPILLAR 303.5E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
NEW HOLLAND L180 SOLID TIRE SKID STEER (A51242)
NEW HOLLAND L180...
2002 CASE INTERNATIONAL MX270 TRACTOR (A51243)
2002 CASE...
2016 Ram 5500 Chassis Truck, VIN # 3C7WRNAL2GG280521 (A50323)
2016 Ram 5500...
2013 Chevrolet Traverse LS SUV (A50324)
2013 Chevrolet...
2017 Ford E450 Super Duty 20 Passenger Bus (A47384)
2017 Ford E450...
