Experience using a bed shaper?
/ Experience using a bed shaper? #1
sros990
West Virginia
JD 990
I would like to use my new tractor to make raised beds in my garden. Does any one have experience using a bed shaper such as the one described here http://www.buctraco.com/BedShapers.htm Do you have to have a lot of skill to use it?(I'm just learning to use the tractor) What are some good sources for bed shapers?
Thanks,
Steve
/ Experience using a bed shaper? #2
Looks real interesting in fact it looks great but they sure are proud of them.
$1200 is a bit high for once a year use on a 100' x 75' garden.
I'll likely go this route Tiller mod
/ Experience using a bed shaper? #3
Here's what I used: two 16" disc hillers mounted behind the rear tires at 45 degree opposed angles. Pulled them with my 18.5 hp JD 4010. Made nice raised rows.
Got the disc hillers for $30 each at Agri Supply. A friend of mine made some clamps to mount them onto my old JD M soil ripper 2x2 diamond bar (that my friend also gave me).
Think you can get soil rippers, or cultivators with chisel plows, from buctraco or other folks (probably Agri Supply). Most of these are made to go on square-mounted 2x2 bars. You can get clamps from them to mount the disc hillers. I had to get my own clamps made because the old JD M soil ripper bars are mounted in diamond pattern, not flat.
Since then, I've bought a couple 12" discs and mounted these onto the disc hiller shanks. Then I've mounted 4 chisel plows for ripping the rows this fall/winter. The smaller discs will sweep between the rows and still allow the chisel plows to drop into the row dirt to do their work.
Ralph
/ Experience using a bed shaper? #4
Check out this Leinbach disc bedder. it's very versatile, and can be had for under $300. They actually have different models not shown on their site. I use a straight toolbar model with two 14" discs, and it also has a furrower and two cultivators.
Leinbach Disc Bedder
John
2019 UTILITY VS2DX 53' X 102" T/A VAN TRAILER (A59910)
2019 UTILITY VS2DX...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
2022 John Deere Z930M (A57148)
2022 John Deere...
2012 Kinze 3600 Planter (A63109)
2012 Kinze 3600...
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
2008 KOMATSU PC200LC-8 HYDRAULIC EXCAVATOR (A64047)
2008 KOMATSU...
