Exhaust Mod
/ Exhaust Mod #1
milkman
Elite Member
Ky. Between Dead Horse Holler and Yellowbank
BX2200, BCS 735
I had a slight exhaust leak under the hood and I thought it was the gasket between the muffler and the manifold. I got a new gasket, but when I removed the muffler, I found that one of the mounting holes in the muffler was ripped out, so I took some cardboard and smeared some grease on the manifold and cut out a pattern for and made a new exhaust flange, then I had a pipe bent up and installed a new muffler.
/ Exhaust Mod
The new pipe comes out of the manifold flange at a slight angle and has a connection just before it exits the engine shroud.
/ Exhaust Mod
We drilled a hole in the side of the pipe and put a bolt through the side of the pipe and tacked it on the inside with the welder.
/ Exhaust Mod #7
milkman, nice looking job you did. I just modified mine tractor to point my muffler forward and drop the exhaust out in front of the left front tire. I was constanting bending and breaking the original exhaust (vertical) off on low hanging things. At least they seemed low to the tractor.
nice work.
/ Exhaust Mod
A notch in the muffler pipe sets over the pin and keeps the vibration and weight of the muffler from rotating the joint, and I don't have to clamp it so tight that it distorts the pipe and make it difficult to get off when I need to remove it.
/ Exhaust Mod
I saw your post just before I started this one and I thought at least maybe we are keeping the world of TBN in balance. /forums/images/graemlins/grin.gif
/ Exhaust Mod #10
Milkman,
Always nice to see someone modify something to make it be like THEY want it to be! /forums/images/graemlins/cool.gif
Man...glad I have a larger tractor along with my BX...those duals sure are appealing! /forums/images/graemlins/shocked.gif
Now the exhaust...well...I admire your work but would not want a pipe sticking up like that around here, with all the trees and branches...
I see Brewdog feels the same...also see Brewdog's location is Western PA...
Must be something in the water here that makes us feel this way... /forums/images/graemlins/grin.gif
Nice job!
/ Exhaust Mod #11
I THINK IT REALLY LOOKS COOL!!!!!IM GONNA do mine. It really takes the lawnmowerish[is that a word?] look the bx has and makes gives it the appearance of a larger tractor.It seems it would send the fumes up and away. Two would look awsome milkman one on each side.We could enter you in the superstock tractor pulls /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gifI think you got the neatest looking bx out there.Id be willing to bet,you got a monster truck or something in your yard too!!
ALAN
/ Exhaust Mod #12
Hey Henro,
I'm about 50 miles due north of you. I think you're right about the water too. Have a great week and keep the rubber side down.
/ Exhaust Mod #13
Hey Milkman,
You are definately keep things in balance here. I finally got a new computer and figured out how to upload pictures on to TBN. Hope the exhaust change works out for you.
Love the duallies , reminds me of a gravely I had, what a beast that little tractor was.
/ Exhaust Mod
I guess I'm never satisfied, I may take the flapper off and put a turn out on the end, I started it the other day and must have been some moisture in the pipe, now I have some soot spots on the hood, and having too much fun to wash it. /forums/images/graemlins/crazy.gif
/ Exhaust Mod #15
milkman, I'd definately do the turn-out.
KUBOTA KX033-4 EXCAVATOR (A65053)
KUBOTA KX033-4...
(UNUSED) REDDICK OFFSET DITCHER, 3PT (A64278)
(UNUSED) REDDICK...
2021 Bobcat UV34 4x4 Gas Utility Cart (A64553)
2021 Bobcat UV34...
2024 CASE TV370B SKID STEER (A65053)
2024 CASE TV370B...
Outdoor fireplace (A64557)
Outdoor fireplace...
Peacock (A64557)
Peacock (A64557)
