eurocardan cover
/ eurocardan cover #1
deereman63
deere 2210
I sheared a bolt on my drive. any ideas how you remove the cover . It can twisted to unlock but that doesnt seem to do much
/ eurocardan cover #2
It's a push and turn thing. You have to press on a pair of latches on either side of the yoke cover while rotating it on the shaft cover. Once released, the yoke cover should slide down over the shaft cover.
//greg//
/ eurocardan cover
thanks got it off not entirely correctly biut without too much damage still not sure whyits designed like that
/ eurocardan cover #5
My finish mower came w/ a Eurocardan shaft and getting the cover off the first time was terrible. Mine had a white stiff plastic piece which held the U joint 'cuff' to the shaft cover. The first time off one of those busted. After getting it apart I ground the pawls which held it in down a bit. I do agree that this design isn't the easiest to maintain.
Atlas Copco Air Compressor & Air Dryer (A62613)
Atlas Copco Air...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A63276)
2017 FORD F-350 XL...
2022 EZ-GO ELITE...
2022 Magni TH5 5.19P (A63689)
2022 Magni TH5...
6R BEDDER (A63291)
6R BEDDER (A63291)
