eurocardan cover
/ eurocardan cover #1
deereman63
deere 2210
I sheared a bolt on my drive. any ideas how you remove the cover . It can twisted to unlock but that doesnt seem to do much
/ eurocardan cover #2
It's a push and turn thing. You have to press on a pair of latches on either side of the yoke cover while rotating it on the shaft cover. Once released, the yoke cover should slide down over the shaft cover.
//greg//
/ eurocardan cover
thanks got it off not entirely correctly biut without too much damage still not sure whyits designed like that
/ eurocardan cover #5
My finish mower came w/ a Eurocardan shaft and getting the cover off the first time was terrible. Mine had a white stiff plastic piece which held the U joint 'cuff' to the shaft cover. The first time off one of those busted. After getting it apart I ground the pawls which held it in down a bit. I do agree that this design isn't the easiest to maintain.
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63689)
2017 Yale GLC050VX...
2014 CASE IH Magnum 340 (A63111)
2014 CASE IH...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
2005 Rolls Rite 26ft. 24 Ton T/A Tag Tailer (A61573)
2005 Rolls Rite...
2017 NISSAN NV2500 4x2 VAN (A59911)
2017 NISSAN NV2500...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
