ethanol
   / ethanol #1
murphy1244
Super Star Member
Ohio
Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y
Was wondering what too much ethanol can do to my car. It seems Get Go put in unblended Ethanol in their tanks Sunday and I got a call from them. I filled up but had a little over a Quarter tank and drove about 50 miles. I also have 20 gallons in containers. The Car is a Mercury Marnier.
   / ethanol #2
I am assuming your vehicle isnt flex fuel
They probably still had some gas in the take. What are they thinking?? 50% ethanol?? more? Less??
If it runs, probably looking at less power and worse fuel economy.
   / ethanol
My car is a 09 Merc the stuff was straight Ethanol
   / ethanol #4
Well the straight stuff is still only e85. And since you already had 1/4 of a tank, you might be around 60-65%.
Did it run okay?? And is the car approved as a flex-fuel vehicle??
   / ethanol
No its not a flex fuel car.
   / ethanol #6
Ethanol attacks the seal and is highly corrosive. From what I have read flex fuel cars have different seals and stainless steel lines. It also attracts water and will evaporate out leaving the water behind.
Flex Fuel Vehicles | Ethanol Retailer
What are the differences between a FFV and a regular gasoline-only model?
The significant difference is the fuel sensor which detects the ethanol-to-gasoline ratio. A number of other parts on the FFV’s fuel delivery system are modified to be E85 compatible. The fuel tank, the fuel lines, fuel injectors, computer system and anti-siphon device have been slightly modified. Alcohol fuels can be more corrosive to certain metals than gasoline; therefore, fuel system parts have been upgraded for high level ethanol use.
Differences Between Flex Fuel Engines & Gas Engines | eHow
   / ethanol
Thanks much!
   / ethanol #9
   / ethanol
I had it towed to my shop. They will look at it Thursday. I imagine a flush and fill the gas tank, change oil and clean out the injection system. Yes?
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
UNUSED SDLANCH SDLC2030FT ALL STEEL CARPORT (A54757)
UNUSED SDLANCH...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2005 Ford F650 SVI Crew Cab Hazmat Truck (A52377)
2005 Ford F650 SVI...
30006 (A53424)
30006 (A53424)
