ethanol
   / ethanol #1
murphy1244
Super Star Member
Ohio
Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y
Was wondering what too much ethanol can do to my car. It seems Get Go put in unblended Ethanol in their tanks Sunday and I got a call from them. I filled up but had a little over a Quarter tank and drove about 50 miles. I also have 20 gallons in containers. The Car is a Mercury Marnier.
   / ethanol #2
I am assuming your vehicle isnt flex fuel
They probably still had some gas in the take. What are they thinking?? 50% ethanol?? more? Less??
If it runs, probably looking at less power and worse fuel economy.
   / ethanol
My car is a 09 Merc the stuff was straight Ethanol
   / ethanol #4
Well the straight stuff is still only e85. And since you already had 1/4 of a tank, you might be around 60-65%.
Did it run okay?? And is the car approved as a flex-fuel vehicle??
   / ethanol
No its not a flex fuel car.
   / ethanol #6
Ethanol attacks the seal and is highly corrosive. From what I have read flex fuel cars have different seals and stainless steel lines. It also attracts water and will evaporate out leaving the water behind.
Flex Fuel Vehicles | Ethanol Retailer
What are the differences between a FFV and a regular gasoline-only model?
The significant difference is the fuel sensor which detects the ethanol-to-gasoline ratio. A number of other parts on the FFV’s fuel delivery system are modified to be E85 compatible. The fuel tank, the fuel lines, fuel injectors, computer system and anti-siphon device have been slightly modified. Alcohol fuels can be more corrosive to certain metals than gasoline; therefore, fuel system parts have been upgraded for high level ethanol use.
Differences Between Flex Fuel Engines & Gas Engines | eHow
   / ethanol
Thanks much!
   / ethanol #9
   / ethanol
I had it towed to my shop. They will look at it Thursday. I imagine a flush and fill the gas tank, change oil and clean out the injection system. Yes?
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A55218)
2019 BOBCAT T630...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
UNUSED IRANCH 16" EXCAVATOR WOOD GRAPPLE (A54757)
UNUSED IRANCH 16"...
2007 Ford F-150 Crew Cab Pickup Truck (A53422)
2007 Ford F-150...
