Etching a Cylinder Rod to Show Position?
   / Etching a Cylinder Rod to Show Position? #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
There are times it would be real handy to know, at a glance, the position of the cylinder rod stroke. An example would be on a top link cylinder where it might be desirable to repeat a level position for a 3PH implement.
I've tried using a magic marker to simply make a line on the rod but it gets wiped off too easily. I remember seeing acid etching kits years ago that allowed marked hardened steel and wondering if something like that might work using a stencil.
Any thoughts?
   / Etching a Cylinder Rod to Show Position? #2
I would be really careful no to do anything that would cause a rough spot on the cylinder rod, it would be likely to tear up the seals pretty quickly. A different solution would be to fabricate a gauge rod that would clamp onto the cylinder rod, sort of like the level indicator rods on a lot of front end loaders. Mark the cylinder with the desired gradations.
   / Etching a Cylinder Rod to Show Position? #3
Just use an indicator like tractors use on the FEL.
   / Etching a Cylinder Rod to Show Position? #5
I had another thought. There are indicators used on trim tabs for boats. I remember on my old Scarab you could see the position of the cylinders on the dash. I don't remember looking at how they accomplish this but that may be another option.
Here is a link.
Teague Custom Marine - Mechanical Trim Indicators
   / Etching a Cylinder Rod to Show Position? #6
+1. Just get a rod and a tube. Put one inside the other. Weld one to the cylinder knuckle and the other to the rod knuckle. make your marks on the rod.
   / Etching a Cylinder Rod to Show Position? #7
I actually kinda like the idea of a mechanical connection between the cylinder and the other end of the cable in the cab where something simple like a ruler could serve as a gauge.
Would be easy to find that perfect setting eachi time and give you a refrence.
   / Etching a Cylinder Rod to Show Position? #10
That just a bad idea. Use some kind of external indicator.
X2 You have already done a few external gauge setups, why this?
2017 Chevrolet Tahoe SUV (A48082)
2017 Chevrolet...
1991 International 4900 Box Truck (A51039)
1991 International...
Sink with table (A50860)
Sink with table...
3/4 Electric Drill (A50860)
3/4 Electric Drill...
2018 Jaguar F-Pace SUV (A48082)
2018 Jaguar F-Pace...
2016 Chevrolet Impala Limited Sedan (A48082)
2016 Chevrolet...
