Etching a Cylinder Rod to Show Position?
   / Etching a Cylinder Rod to Show Position? #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
There are times it would be real handy to know, at a glance, the position of the cylinder rod stroke. An example would be on a top link cylinder where it might be desirable to repeat a level position for a 3PH implement.
I've tried using a magic marker to simply make a line on the rod but it gets wiped off too easily. I remember seeing acid etching kits years ago that allowed marked hardened steel and wondering if something like that might work using a stencil.
Any thoughts?
   / Etching a Cylinder Rod to Show Position? #2
I would be really careful no to do anything that would cause a rough spot on the cylinder rod, it would be likely to tear up the seals pretty quickly. A different solution would be to fabricate a gauge rod that would clamp onto the cylinder rod, sort of like the level indicator rods on a lot of front end loaders. Mark the cylinder with the desired gradations.
   / Etching a Cylinder Rod to Show Position? #3
Just use an indicator like tractors use on the FEL.
   / Etching a Cylinder Rod to Show Position? #5
I had another thought. There are indicators used on trim tabs for boats. I remember on my old Scarab you could see the position of the cylinders on the dash. I don't remember looking at how they accomplish this but that may be another option.
Here is a link.
Teague Custom Marine - Mechanical Trim Indicators
   / Etching a Cylinder Rod to Show Position? #6
+1. Just get a rod and a tube. Put one inside the other. Weld one to the cylinder knuckle and the other to the rod knuckle. make your marks on the rod.
   / Etching a Cylinder Rod to Show Position? #7
I actually kinda like the idea of a mechanical connection between the cylinder and the other end of the cable in the cab where something simple like a ruler could serve as a gauge.
Would be easy to find that perfect setting eachi time and give you a refrence.
   / Etching a Cylinder Rod to Show Position? #10
That just a bad idea. Use some kind of external indicator.
X2 You have already done a few external gauge setups, why this?
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A48836)
2007 Chevrolet...
PALLET OF ARMSTRONG TILE FLOORING (A50460)
PALLET OF...
2017 Ford Explorer XLT SUV (A48082)
2017 Ford Explorer...
2018 Chevrolet Tahoe SUV (A48082)
2018 Chevrolet...
John Deere 835M (A50490)
John Deere 835M...
