Estimate the Weight of this log
   / Estimate the Weight of this log #52
Because I think my FEL seems a bit weak, I stuck a new gauge in one of the 3rd function connections. Reads about 2450 lbs.
Isn't it supposed to be 26XXpsi?
   / Estimate the Weight of this log #54
Good question. My FEL says a max of 2630 if I remember correctly.
Would 200 more psi make much difference given only like 7 percent?
(Assuming my gauge is accurate.)
   / Estimate the Weight of this log #55
It would make more than a 7% increase in lift capacity. How is your gauge set-up? do you have it tee'd into the lift circuit? if so, look at how many PSI it takes just to lift the weight of the empty bucket and loader frame.
I am guessing ~600psi or so. So no matter what, you always need that 600psi just to lift the dead weight. That leaves you currently with ~1800psi for lifting loads. So being 200psi short is about 11%.
What is your loader rated to lift? ~2000# range? That 200psi would be good for a few hundred pounds more lift.:thumbsup:
   / Estimate the Weight of this log #56
Current test was a gauge stuck into a 3rd function connector.
I've read there is only one relief valve for my tractor although I don't know that for sure.
I think the FEL is rated around around #1900. A few more hundred lbs lift would be welcome, as I don't think I am getting that lift currently.
A bit hard to say, but that is my impresesion.
   / Estimate the Weight of this log #57
What does the gauge say when the pistons are at the end and the relief valve opens? Or does it open at all?
I think the owners manual lists the specs of the cylinder. Punch them in this calculator with the pressure you have and what it is supposed to be.
Hydraulic Cylinder Calculator
   / Estimate the Weight of this log #59
correction: with full rpm the gauge in my 3rd function connector reads close to #2500.
   / Estimate the Weight of this log #60
If the log was just cut it could have weighed about 3075 pounds as I figure it.
TREE PLANTER (A52708)
3079 (A56857)
3079 (A56857)
2011 Ford F-550 ETI ETCMH37IH 37ft. Insulated Material Handling Bucket Truck (A55973)
2011 Ford F-550...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
Mini Skid-Steer Grapple Bucket (New/Unused) (A59225)
Mini Skid-Steer...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
